Old 08-07-2006, 08:08 PM
SyrianMafioso SyrianMafioso is offline
fuel filter problem
Ive been an avid reader on this forum for a few years now... you guys are mechanic geniuses for real.
Now on to the real deal... as far as changing my fuel filter is concerned (On a 97 LS), I'm stumped as to how to remove the filter from the bracket that mounts it onto the frame. Yes I know its a simple problem but I cant for the life of me figure it out.
I used a 13mm to unscrew the bracket from the frame, but the bracket seems to be all in one piece around the filter and the piping overhead, with no release or anything.
Old 08-07-2006, 08:53 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: fuel filter problem
The holder snaps into the fuel and brake lines above, just remove them bolts holding it on the fame remove the tubing going to and from the filter and pull down, the hold will come with the filter.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 08-08-2006, 08:56 AM
doeyh doeyh is offline
Exactly...
The holder fits filter tight.
A few drops of used oil will help get it in.
Old 08-08-2006, 12:03 PM
Thanks a lot... but now how am I to remove the old filter from its holder and slide the new one in there?
Old 08-08-2006, 12:40 PM
BlazerLT's Avatar
AF -Advisor
Hammer the old one out.
Then grease the new one and slip it on.
Old 08-08-2006, 07:03 PM
Much simpler than I was makin it seem... Thank you homeys I appreciate it
Old 08-08-2006, 08:22 PM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
Unless it's really rusted in there bad, on '97s they just snap fit into the bracket.
Remove the pinch/squeeze connector off the forward facing fitting first, then use 2 wrenches to remove the fitting from the back of the filter.
When the hoses are off, grab the filter firmly and twist it out of the bracket.
Did mine yesterday, took all of 10 minutes from start to finish.
It's my opinion, don't take it personal.
'04 T&C,'01 Blazer ZR2, '97 Blazer, '97 Sunfire, '85 Vette, '79 Civic, 94 FLSTC
