Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 08-18-2002, 10:40 PM
97wvmax 97wvmax is offline
Send a message via AIM to 97wvmax
Question supercharger question
ok, i have a 97 max, still stock everything pretty much. i have 95500 miles on my car, is the mileage too high to add a supercharger onto? will the supercharger add more wear and tear to my engine? high maintinence? i want to kno everything i can find out about these before i look into puttin 4000 into it. oh, and does the SC make ur car fail inspection? get in deep shit if cops find? anything else bout that would help too
Old 08-18-2002, 11:24 PM
2001 AE's Avatar
2001 AE 2001 AE is offline
Re: supercharger question
From my research yes it is too late to add a supercharger to your Max with 95k + miles due to the fact that the SC will add extra wear to your engine and with higher mileage vehicles it really is not worth the risk. As for the second question you will pass inspections with a SC recommended for your engine.
Old 08-18-2002, 11:37 PM
Edho2002 Edho2002 is offline
Anything to add more power to your car will produce more wear but there are tons of people that still do it. I remember hearing about someone putting a SC on a max that had 200,000+ miles on it so it's all up to you. My guess is if you put a SC on with no mods to your pulley and having a manual tranny and not driving it too hard you could probably get 100K more miles out of your engine. Assuming you take really really really good car of your car. If you have and auto tranny then that will give out before your engine does and if you miss oil changes by thousands of miles then there will be more wear. Its all up to you though, weigh the good and the bad before you do something like that, liek you said
Old 08-19-2002, 08:39 AM
what about a turbo, same thing jus have to weight out good and the bad????
Old 08-19-2002, 10:37 AM
mtrai760 mtrai760 is offline
Send a message via AIM to mtrai760
Simple way to find out. Do a compression test. If all the numbers look good, then go for it. If you have low compression or if the numbers vary by over 15psi per cylinder, then look into getting a new engine first.
5spd VLSD
15.2@92mph
180hp & 193tq
Faster than jOO!
A hunting we will go...
Old 08-20-2002, 02:47 AM
2001 AE's Avatar
Excellent advice
Old 08-20-2002, 08:44 AM
funnylittlman funnylittlman is offline
Send a message via AIM to funnylittlman
I agree
I wholeheartedly agree w/ you
99 Max SE Limited
APEX'i Cat Back Exhaust
PIAA Super Whites
Clear Diamond Cut Bumpers
Cleared Rear Corners
H&R Sport Springs
KYB AGX Adjustable Struts & Mounts
Old 08-20-2002, 11:07 PM
ok, i am stupid so i have to kno how to do a compression test
Old 08-20-2002, 11:24 PM
Chris's Avatar
Chris Chris is offline
Oldie
Send a message via AIM to Chris Send a message via MSN to Chris
Buy a compression tester for about $20. Then, unscrew a sparkplug from a cyliner. Plug it in. Turn the engine over a few times (pretend to start the car). REcord the psi recorded. Repeat for all the cylinders.
PS, a turbo and supercharger will both cause about equal amounts of wear and tear.
You can live in a car, but you can't drive a house!!
MSN: [email protected]
Old 08-21-2002, 12:30 AM
would an engine rebuild or somethin like that be any help. anything that would help other than a new engine?
Old 08-21-2002, 09:41 AM
Chris's Avatar
Oldie
Usually, with a supercharger, you mainly have to be worried about sealers. That is, the first things to go would be piston rings, head gaskets, etc. So, you might just install the supercharger, then, if something goes wrong, fix it. If all is ok, you save yourself some money.
Old 08-21-2002, 01:06 PM
Paonessa Paonessa is offline
where would i be able to buy a new 1995 maxima engine. i know i could fit a 96 97 or 98 but i want an obd1 emissions engine. will my local nissan dealer be able to get their hands on it and what would i be looking to spend
Old 08-21-2002, 02:27 PM
r the sealers going bad the only thing that ususally happends or will the engine jus blow or wat?
Old 08-21-2002, 04:57 PM
When the piston rings go bad, you will start burning excessive oil, and you will also loose a lot of power. Eventually, this could lead to oil starvation, or you could loose a whole cylinder due to the compression failure. You can't get a good used engine with low miles for around $500-800, which really isn't much to spend when you are talking about $4k for the S/C.
5spd VLSD
15.2@92mph
180hp & 193tq
Faster than jOO!
Old 08-21-2002, 10:47 PM
what other kind of engine that would be stronger and faster is capable of being put into a maxima? how much would an engine with low mines cost?
