Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 08-07-2006, 06:48 PM
lucyh23 lucyh23 is offline
type S prelude
whats goin on people . i got a 94 prelude si. i am thinking about putting high compression type s prelude pistons in my car. do ya'll think that is a good idea or what. and someone please tell me a little more about the type s motor in a prelude. i heard it was the best one a prelude can have..
thanks
lucyh23
Old 08-14-2006, 12:56 AM
honda_racing101's Avatar
honda_racing101 honda_racing101 is offline
Send a message via AIM to honda_racing101 Send a message via MSN to honda_racing101 Send a message via Yahoo to honda_racing101
Re: type S prelude
Type-S engine had ATTS, so count that out on trying to shoehorn it in your 4th gen.
dSoc member #67
1995 Honda del Sol EG2 VTEC Milano Red. RIP :crook:
1994 Honda del Sol EG1 S-full VTEC conversion.
Buy my Del Sol parts!!
Old 09-14-2006, 12:39 PM
J-Wat J-Wat is offline
AF -Advisor
Re: type S prelude
The pistons will be ok in your motor, but the Type S cams will damage it if you try to add those pieces.
Old 09-20-2006, 01:27 AM
AllmotorBB6 AllmotorBB6 is offline
Re: type S prelude
damage?...explain
Old 09-20-2006, 02:47 PM
AF -Advisor
Re: type S prelude
On stock usdm valve springs, the type s cams will wear them out faster
Old 09-20-2006, 02:58 PM
ShoofIsLudin ShoofIsLudin is offline
Re: type S prelude
Doesn't the Type S head also have a very mild p&p to go with the cam profiles in there?
Old 09-20-2006, 03:11 PM
AF -Advisor
Re: type S prelude
i believe so
btw: im not saying the type s wont work just that they will wear out your stock springs faster than normal
Old 09-20-2006, 04:29 PM
Re: type S prelude
i believe so
its not the springs you have to worry about. There are a couple of other things that are more important
1) rocker arms
2) retainer to valve guide/seal clearance
In the type S head, the valve guides are seated lower into the head to give more clearance for the larger lift. This clearance issue with the valve guides in turn effects the rocker arms that control the valves, therefore scarring and misshaping them arms are wearing down the cam lobes.
