Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 08-07-2006, 04:02 PM
knuckle ears knuckle ears is offline
Transport 3.8L
Anybody know where the vehicle speed sensor buffer (VSSB) is located on a 93 transport. I have a wiring diagram but don't where or what it looks like.
Trying to get my cruise control working. Replaced the cruise control servo under the hood and the signal light handle/ crusie switch on the steering wheel. Checked the brake/cruise switch and okay. No luck so far.
The speedometer works but not the odometer.
Any suggestions?
Old 08-08-2006, 10:22 AM
LMP's Avatar
LMP LMP is offline
Re: Transport 3.8L
3.1: UNder dashboard, under glove box, above convenience center
3.8: speed pickup fed direct to the PCM which outputs a 4000 pulse per mile signal to instrument panel.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 08-08-2006, 10:30 AM
Re: Transport 3.8L
Everything else on the van works well, meaning the PCM is also working. But could the PCM still cause the cruise not to work?
Old 08-10-2006, 01:23 PM
Re: Transport 3.8L
Cruise control now working. I had replaced the cruise control handle on the steering wheel with one from a chev mini van at first. Nothing worked. I then got one from a 93 transport and now everything works.
Maybe the chev won't work on a pontiac or it was no good. All the connections were the same for each one.
