Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 08-07-2006, 12:51 PM
dodgeneonfan dodgeneonfan is offline
Unhappy HELP!!98 Dodge Neon SPORT DOHC; where are the timing marks
Hello friends, what's happening.? I recently bought a 98 dodge neon sport with a 2 L DOHC 4 cyl engine; it has 105k miles. I replaced the water pump since it went bad and forgot to make a mark on the cams as to their original position before removing the timing belt as well. It turns out the exhaut cam moved a bit as i was working on the water pump and I had great difficulty getting it timed back right again. By trial and error, I moved the exahust cam forward and back 1 tooth, then 2 teeth. Now it seems the engine is running excellent again, but the chech engine light came on 5 min into the test drive. Got it checked out at auto zone and the P1390 code says the cam could be off 1 or more teeth. I want to correct the mistake, but I don't know of any timing marks on the cams at all. I know the crankshaft and pulley have a mark for TDC, but the're are no dots on the cams just some stamped writing. Does that mean anything? How should I line things up on the cams and crankshaft assuming there might be some camshaft marks which I'm unaware of. I'd love to see any illustrations.
I'd owe you people one if you help me figure this one out
Old 08-07-2006, 03:31 PM
Bear Bear is offline
Re: HELP!!98 Dodge Neon SPORT DOHC; where are the timing marks
Look at the cam sprockets (head on) and you should see a mark/line at edge of one tooth on each cam.
Old 08-07-2006, 10:33 PM
growe58 growe58 is offline
The autozone site has online repair manuals. I'm not sure if this link will work, but it includes pretty good diagrams.
http://www.autozone.com/servlet/UiBr...3d801986e7.jsp
Keep in mind that you can just remove the little inspection cover to check the valve timing, you don't have to remove the entire timing belt cover (although you will have to remove it all to re-do the timing).
