Old 08-07-2006, 11:17 AM
Brettriehl101 Brettriehl101 is offline
Exclamation New clutch now we cant get it in gear! HELP!!
ok yesterday we finished putting together my brothers old cav (96 Z24) he blew the clutch so we took it all apart got the new one it and finally had time to get it all together again. So we started it in neutral with the clutch in... and we can keep it running but if u depress the clutch it turns off.. and when u try and shift into a gear it feels like something is blocking u from doing so. the shifter can not even go by the 1st and 2nd gears... and 3 4 5 and R do not allow it in... does anyone have any ideas here? thanks
Old 08-07-2006, 11:46 AM
formulaross formulaross is offline
Re: New clutch now we cant get it in gear! HELP!!
Not being able to get it into gear with the engine running is a sign that the clutch is not disengaging. Did you disconnect the slave cylinder during the clutch replacement? If so, correctly bleeding the hydraulic slave cylinder can be a real PITA! Just my opinion, though.
Old 08-07-2006, 11:49 AM
ya i think we did... its like there is something blocking eatch gear thou.. we can move it in neutral between 3-5 but it doesnt move over to the 1st area in neutral.. and when u try and get it in gear it feels like there is osmething blocking it from pushing in...
Old 08-07-2006, 01:20 PM
CavLCD128 CavLCD128 is offline
Send a message via AIM to CavLCD128
this might not even be close to the problem but check the shift cables, make sure they are where they should b
ThE neW wHiP:
Old 08-07-2006, 05:50 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
you read my mind, i had a VERY similar problem once, and it turned out to be the shift cables, they needed to be replaced
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
