Old 08-07-2006, 09:59 AM
91S10's Avatar
91S10 91S10 is offline
Send a message via AIM to 91S10 Send a message via Yahoo to 91S10
Head Gasket
Hey i have an 89 civic hatch with a 1.5 D15b2. I need a new head gasket and i figured since ill have the head and everything off im gonna put a underdrive pulley on and a cam gear? Do i need different belts when putting the pulley on or do i just use the same one and is it smart to replace the timing belt if im taking it off and putting it back ok?? Thanks for any help!!!
Old 08-07-2006, 10:38 AM
thefooshmeister thefooshmeister is offline
Send a message via AIM to thefooshmeister
Re: Head Gasket
no you wont need different belts since the only thing different is the weight of the gears. it would probly be better to change them all since youre workin on that area of the motor so you dont have to go back to it later or worry about it when youre driving.
98 Jetta GLX VR6-vroom vroom!!
91 CRX Si-R..busted..
Old 08-07-2006, 06:17 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Re: Head Gasket
When was the last time you did timing belt/water pump? I'd say if its been a while, nows the best time to get those replaced...if you feel you can.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 08-07-2006, 06:58 PM
Hybrid1990crx's Avatar
Re: Head Gasket
no need for a cam gear with the stock cam.
underdrive pulleys cause premature wear of crank bearings as well.
