Roof is hard to remove/install...
I just got a Del Sol and i took the roof out the other day and i had a hard time getting it to lock back in. It seemed like something wasn't lining up right. Is there any tricks to make it easier ? Is it easier to lock one side it at a time or just set it on flat and try to find the right position for it ?
the first thing you need to do is make sure everything is lubed up on it. check out www.teamdelsol.com for info on that. then make sure your car is sitting on flat ground. the frame of the car is pretty weak and having the car on an uneven surface twists the body just enough to make the roof hard to put on. if that still doesnt work, then hopefully someone else has some suggestions
hey
hey either ur top is bent or ur frame is bent thats my guess
