I'm Confused
Ok, so I recently got my SI from a junk yard. The Vin reads as an SI and the engine in the car was a D16Z6 when I bought it. Here's the confusing part. I thought that if an SI came with a sunroof that I would also have power locks and windows. Mine doesn't but the fuse box is set up to provide for it and I haven't had a chance to see if the harness is there. Would I be wrong in thinking that, and can I use the door internals from my sedan with the current glass in my si to get power locks and windows? I know that I would still need the panels, wire harness, and switches from a coupe but is the power window unit the same?
Re: I'm Confused
I believe the 92-95 SI don't come with power windows or power locks. I have seen 3 different ones that own by my other buddies are all non-power windows and locks.
The fuse boxes are the same for both styles to reduce cost, but most likely you will have run all the wires for your SI. You can just get the power lock actulators from alarm systems. I have never look into the power window part for this particular car (IMO if you want those features, then coupe is the choice), but if the coupe and the hatch has the same size door and glass then you should able to swap the regulators from your coupe into your hatch.
Power is nothing without control The fastest driver is the one with skills 95 Civic EX 83 Toyota Starlet 07 Ducati Monster S4RS |
