Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-06-2006, 11:55 PM
Killa's Avatar
Killa Killa is offline
Unhappy Im feel that I loose alot hp
I can fell my my car is getting slow, I cant able to do boost leak test right now, I have few question please answer, ( Im kinda drunk btw sorry )
My spark plug keep getting black ?
I can heard my turbo spool under boost, I try to stay under boost any gear possible, I shift every 3k, and the needle on my boost gauge is about to go to 1psi, then I shift, I can heard my bov, is this normal, can bov open even 1 psi ?
after I put my 15 inc wheel on, 90% tread left is in front, and 75% is in the back. When ever I shift I can fell, something wrong in the back. Should I put 16inc wheel back on ?
last week, or last couple week, I took my friend to track, but we lost in the wood, I accident fall into really big hole, now when ever I turn all the way, I can heard the clunk noise ( only one time ) what is that ? , and I think my shock and strut is bad, how do I check if it bad ?
thanks guy.
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 08-07-2006, 07:30 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: Im feel that I loose alot hp
lol...I love reading your posts even though I always get a headache.
Spark plugs are getting black because you are running rich.
Wheel size should have nothing to do with whatever it is you feel in the back of the car when you shift.
NO fucking clue what you said there man, but it sounds like you messed up something like a ball joint or other part of the suspension.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 08-07-2006, 07:46 PM
Killa's Avatar
I drove my car into really big chicken hole, now my car making a clunk sound, when ever I turn left or right ( it make sound, when I turn really hard ).
Running rich because, boost leak right ?
when I did my boost leak today, VC breather hose come out alot of air, so I cover it up, it that right ?
GM FOR LIFE !!
95 camaro lt1
Old 08-08-2006, 12:30 PM
Killa's Avatar
I found another leak today, the leak come from the TB gasket ( j pipe, there are 2 gasket, one is next to the manifold, and one is next to J-L pipe ( what ever that call is ), is good ideal to replace 2 of them the same time ? do I need to use silicon on the new gasket to seal it ? or just put in the new gasket without the silicon ? is those 2 gasket the same size ? or different ? thanks.
here the pix incase you guy, dont know what Im talking about BTW this is really old engine pix, it much cleaner now, no leak from oil cap.
GM FOR LIFE !!
95 camaro lt1
Old 08-08-2006, 12:38 PM
wanaplay134 wanaplay134 is offline
Send a message via AIM to wanaplay134
you dont have to use gasket seal but it will last alot longer if you do and you should replace both throttle body and elbow gaskets at the same time it will save you alot of hassle.
the clunking sounds like you broke a ball joint or a tie rod end is coming off i couldnt really tell you with out looking at it but i would get that fixed quick before you screw something up.
get a couple cans of degreaser and clean that nasty ass engine bay while you are at it also.
and what the hell were you doing drinking and driving
1992 eagle talon tsi awd
xtd stage 3 six puck/apexi 3' downpipe and exhaust/ngk plugs/taylor thunderbolt wires/manual boost controller set at 20psi/walbro 255 with rewire/autometer boost gauge/turbo xs rfl blow off valve/arp headstuds/ to4b vtrim turbo/dnp tubular manifold with o2 housing and tial 38mm wastegate/eagle rods/ross pistons/acl bearings/arp rod bolts/arp main studs/aeromotive fuel pressure regulator and all stainless lines/aem fuel rail/slowboy street front mount kit
Old 08-08-2006, 12:41 PM
Killa's Avatar
LOL I already told you, that is my old engine pix, it really cleaner now. And Im not drink and drive, I was lost in the wood, that have tree and hole every where, TB and elbow gasket are the same ? autozone sell some kind of spay seal gasket is that good ?. I have some blue rvt silicon, can you tell me how to apply in to the gasket ( like you put silicon both side of the gasket, or just one side ? ) thanks
GM FOR LIFE !!
95 camaro lt1
Old 08-08-2006, 02:07 PM
dont use the spray the rtv is good. yea just put some on your finger and put a light coat on both sides and you should be good tighten it down and let it seal for a little bit.
make sure you clean everything like the throttle body since it is off probally black the surfaces and all that.
Old 08-08-2006, 03:12 PM
Killa's Avatar
Can you tell me, where I can buy the elbow gasket ? or what the hell that caller.. I try autozone, napa, orealy ( spell ), advant auto part, none of them know what the elbow gasket is, I brough my haynes book with me , and show them the pix if the elbow gasket, they have no ideal, what the hell it is.
GM FOR LIFE !!
95 camaro lt1
Old 08-08-2006, 04:08 PM
damn thats messed up you can get it at extremepsi.com and they can get it too you in 2 days. if any of those places sell the throttle body gasket i would just buy 2 of those and that should work if not just modify it a little.
Old 08-08-2006, 04:42 PM
Killa's Avatar
http://www.extremepsi.com/store/cust...cat=863&page=1
Is that what you are taking about ? if I order it , they gonna send to me the gasket, that from the elbow to TB right, cause I can get TB ( the one that next to the manifold for $1.68 ).
GM FOR LIFE !!
95 camaro lt1
Old 08-08-2006, 11:49 PM
yep sounds like the gasket you need to me
Old 08-09-2006, 12:30 AM
Killa's Avatar
$ 13.00 for that gasket !!
GM FOR LIFE !!
95 camaro lt1
Old 08-10-2006, 01:34 PM
Killa's Avatar
I replace the TB and elbow gasket, spray alot soup on the TB and elbow ( only on top, I cant spay at the bottom of the TB and elbow ), I dint saw any bubble like I saw before, but I still heard a psssss sound coming from under the TB or Elbow, any one have any ideal where that sound come from, mabe ISC O-ring ? Thanks
GM FOR LIFE !!
95 camaro lt1
Old 08-13-2006, 02:06 PM
Killa's Avatar
GM FOR LIFE !!
95 camaro lt1
