Old 08-06-2006, 11:16 PM
kelly_b kelly_b is offline
Headlight problems
Has anyone encountered this problem with their Trailblazer? I have a 2002 model and the right, dim headlight keeps burning out. I wrote off the first replacement bulb as a defective bulb since it only lasted about three weeks. The second time I replaced the buld the connector was burned out and I had to replace it also. I had the tail lights replaced due to a recall but have not found a recall on the headlights.
Old 08-07-2006, 07:25 AM
rodeo02 rodeo02 is offline
Re: Headlight problems
Are you running OEM wattage replacement lamps? Anything other that what came with it from the factory can overheat the lamp holders, etc..
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 08-07-2006, 09:27 AM
Yes, the replacements were OEM.
Old 08-07-2006, 01:24 PM
Have you had any other electrical issues aside from the head and tail lights? I guess it could be possible the voltage regulator is shot in the alternator, but I'd think you'd have issues aside from the headlamps if that was the case.
Joel
Old 08-27-2006, 07:57 PM
dnorris dnorris is offline
Had the same problem in my 03 Trailblazer. Check the recepticle that you are plugging the bulb into. One of the wire to the recepticle has a crack in it and the wire was in a bind and that kept shorting the bulb out. go to you auto parts store or chevrolet house and they have a replacement recepticle that you have to solder. DO NOT let them try to sell you the whole lamp assembly. The replacement recepticle is less thatn $10
Old 08-27-2006, 08:35 PM
Thanks and that does make sense. I was thinking that I was going to have to buy the whole lamp assembly. There hasn't been any other electrical problems in the vehilce or with any of the other lights in the headlight assembly.
Old 09-12-2009, 11:59 AM
just51peachy just51peachy is offline
Red face Re: Headlight problems
[quote=kelly_b;4253563]Has anyone encountered this problem with their Trailblazer? I have a 2002 model and the right, dim headlight keeps burning out. I wrote off the first replacement bulb as a defective bulb since it only lasted about three weeks. The second time I replaced the buld the connector was burned out and I had to replace it also. I had the tail lights replaced due to a recall but have not found a recall on the headlights.
[/quote I am having the problem. I hope it is not to expensive to have this fixed. Thanks
Old 09-12-2009, 12:18 PM
maxwedge maxwedge is offline
A990 racer
The connectors were an issue with my 2002 on both sides, I installed a HD replacement connector from NAPA.
