Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 08-06-2006, 10:11 PM
gspservice gspservice is offline
Heating up
91 Camry is starting to heat up not a lot just to the halfway mark with slight fluctuation takes about 5 to 7 miles to happen. Both fans are running and radiator is full. whats the odds on the thermostat not opening all the way or the sensor being defective ?
Old 08-06-2006, 11:15 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Heating up
What is normal for your car?
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 08-07-2006, 09:19 AM
idmetro idmetro is offline
Re: Heating up
In my case my 91 normally sits right at the 1/2 mark.
Old 08-07-2006, 10:43 AM
Brian R.'s Avatar
Resident Chemist
Re: Heating up
I don't understand what the difference is between the normal behaviour and what you're discussing in the first post.
Old 08-07-2006, 02:51 PM
hassanbigboss hassanbigboss is offline
Send a message via MSN to hassanbigboss
Re: Heating up
gspservice, I do not want to sound ignorant towards your problem but I think that going towards the half mark is "Okay" specially with the extremely hot summer we are having in the states. But just for your comfort get your radiator flushed and have it filled with the Toyota red coolant, this should solve the issue that is if there is any.
Old 08-07-2006, 09:07 PM
Re: Heating up
Not really sure, no numbers just a C and H but it is running hotter then normal with some bouncng back and forth. always ran steady before.
Old 08-07-2006, 09:15 PM
Re: Heating up
No thats not the problem after years of a steady reading even on the hottest days something is off. I will be flushing out the system when I change out the thermostat and see what happens. Just strange how it happen over night and takes 5 to 7 miles to start acting up.
thanks for the help
Old 08-13-2006, 06:06 AM
EA6BMECH's Avatar
EA6BMECH EA6BMECH is offline
Re: Heating up
Try a thermostat, if that isn't it, get ready to buy a radiator.
Old 08-13-2006, 08:11 AM
DFBonnett DFBonnett is offline
Re: Heating up
Also consider the possibility of the coolant temp sensor getting flaky.
Old 08-13-2006, 11:32 PM
Re: Heating up
Well I change the themostat and flushed out the system and it seems to have done the trick. I'am thinking the themostat was on its way out and starting to stick.
