Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 08-06-2006, 09:50 PM
switch55 switch55 is offline
strange chirping noise
I have a 94 4x4 with a 22re. When I am in first gear and step on the gas I can hear a loud squeaking/chirping noise. It sounds like it is coming from under the truck. I think it might be coming from the transmission, but not really sure. If anybody knows about the problem or how to fix it, i would really appreciate it. thanks
Old 08-07-2006, 12:26 AM
KimMG KimMG is offline
AF - Advisor
Re: strange chirping noise
Did you check the belt?
Old 08-07-2006, 12:14 PM
I thought it might be the belt at first, then I changed it and it still does it?
Old 08-07-2006, 03:15 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
is your tries sping on the ground? sounds dumb but that might be the noise. Does it do it in 2ed if you stomp on it?
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 08-08-2006, 06:37 PM
If I am really on the gas it will chirp when I shift to 2nd.
Old 08-08-2006, 07:58 PM
97cavalier's Avatar
might just be the tires loosing grip.
Old 08-09-2006, 01:04 AM
it's not the tires slipping, because it will sometimes do it when downshifting into 2nd and the engine is revving high. It sounds like a bird chirping it's guts out under there.
Old 08-09-2006, 11:17 AM
ToyotasGoneWild ToyotasGoneWild is offline
Cool Re: strange chirping noise
Switch,
Hey I ran into that problem driving from Florida to Dallas and within 30 miles of Dallas I hear this strange noise from under the truck. Well I drove the 30 miles to Dallas and wouldn't you know it my tranny blew 5th gear and then on down the line it went. the noise was from the gears spinning on their shafts. I hope t his isn't your issue cause it will take about 1600.00 to fix the damage. If your throw on your shifter is wide then your linkage inside the tranny is faulty and this will cause future tranny problems.. Hope you find out what your issue is....
Old 08-10-2006, 05:47 PM
Thanks for heads up. I really hope that isn't the case, how long did it take for the other gears to go out. Mine's been making noise for a month now.
Old 08-10-2006, 06:49 PM
Is your shifting throw short or long, if it is long them your linkage is wearing and the tranny is not adjusted right...HOpe you remedy this beofre you loose your gears out on the trail or in rush hour traffic..
Old 08-10-2006, 11:37 PM
97cavalier's Avatar
just take it to a tranny shop and they will test drive it for frr, and tell you what it is.
Old 08-12-2006, 02:55 PM
augie7071 augie7071 is offline
I had that problem over the years with other trucks. Check the u-joints on main drive shaft. Thats been a fix for me
Old 08-15-2006, 12:27 AM
97cavalier's Avatar
also any grease fitting, grease them up.
