Old 08-06-2006, 09:39 PM
paqman's Avatar
paqman paqman is offline
DIY tranny flush?
Anyone know where I can find instructions to flush the tranny fluid on a 2001 Intrigue? Never done it before, but I don't figure it can be too hard.
Thanks.
Current Vehicles:
2008 Nissan Altima ~ 115k miles
2010 Nissan Maxima ~ 74k miles
2007 Toyota Sienna LE ~ 145K miles
Goners
1997 Ford Escort ~145k miles (SOLD)
2013 Kawasaki Ninja 300 ~13k (SOLD)
1983 Honda Magna V45 ~13k (SOLD)
2004 Mazdaspeed Miata ~90k (SOLD)
2001 Ford Mustang GT ~86K (SOLD)
2007 Suzuki Boulevard M50 ~12k (SOLD)
2001 Nissan Maxima - (TOTALLED)
2001 Oldsmobile Intrigue (SOLD)
1991 Nissan Maxima (TOTALLED)
1989 Pontiac Grand Am (SOLD)
Old 08-06-2006, 10:10 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: DIY tranny flush?
To do a proper tranny flush you need the right equipment. There is a full flush and fluid exchange. But why do you want to do a tranny flush? Depending on your mileage in most cases I would not recommend it.
A pan drop and ATF fluid replenishment to include screen filter replacement is normally the best way to go.
Timeslip 08/12/06
AF Community Guidelines
Old 08-06-2006, 11:16 PM
paqman's Avatar
Well, she's been shifting a little hard lately, the check engine light came on, with a code for the torque clutch converter. We've had problems in the past with it being stuck, and I was told that a good tranny flush with some lubeguard would remedy it for a while. We are planning on getting the proper work done later, but would like to see if getting the tranny fluid flushed would help the problem at least temporarily. But if it's going to take special equipment, then maybe I ought to just have the shop do it.
Current Vehicles:
Goners
Old 08-06-2006, 11:19 PM
kmohr3's Avatar
kmohr3 kmohr3 is offline
Send a message via AIM to kmohr3
I agree with bnaylor, plus you can get 7 quarts out just by dropping the pan. I was kind of surprised, on some cars you just get about 3 quarts by dropping the pan. Also I used Mobil 1 synthetic ATF upon refilling. A bit pricey but worth it in the long run.
Old 08-07-2006, 12:00 AM
paqman's Avatar
So is it going to be something a shop should do? Cause I don't have any special tools or anything, and I would like to get the job done good.
Current Vehicles:
Goners
Old 08-07-2006, 08:59 AM
atoyota4x4 atoyota4x4 is offline
Just my 2 cents, replace one quart of fluid with Lucas Transmission lube. Very good stuff. I have done mine twice since I've had it and used it both times.
Old 08-07-2006, 09:24 AM
paqman's Avatar
Thanks for the advice, I'll keep that in mind. Still need to find out how though.
Current Vehicles:
Goners
Old 08-07-2006, 05:46 PM
BNaylor's Avatar
If you are the one having re-occuring TCC problems then you might consider taking it to a trans shop. There is no guarantee the Lubegard will help.
If you prefer giving an additive a final shot then use something like SeaFoam. It will do a better job freeing up sticky solenoids in the valve body than Lubegard or Lucas.
Timeslip 08/12/06
Old 08-07-2006, 10:18 PM
paqman's Avatar
Yup, that's me. I have had it into a tranny shop. We're going to have to get the valve body worked on or something. I just wanted to flush the tranny in the mean time till we get the work done. But I had my favorite GM guy do the flush today, and he uses some special chemicals for the additive. I'm not sure what they are, but they seemed to do the trick. Least until we get the real work done.
Thanks.
Current Vehicles:
Goners
Old 08-07-2006, 10:38 PM
BNaylor's Avatar
Thanks.
I thought so but sorry to hear that. Trannies problems are a real PITA.
It sounds like you got the full flush which GM recommends when there is a known or suspected hydraulic related malfunction. I believe the flusher dealers use are the Kent Moore brand. A GM approved flushing detergent is used in full flush to encapsulate fine particles of metal and clutch material so that was proper procedure.
Good luck and let us know if your problem ever gets resolved.
Timeslip 08/12/06
Old 08-07-2006, 11:12 PM
paqman's Avatar
Good to hear I did the right thing. So yeah, I'll let you know what I do. Getting into the valve body is so expensive, I might as well get a re-manufacturered tranny put in. But we'll see.
Current Vehicles:
Goners
