Old 08-06-2006, 07:54 PM
cbear cbear is offline
Unhappy 98 escort zx2 smoke from engine and tailpipe
A week ago I checked my oil and it was very low(almost none) so I put 2 qts in. Then I headed for the store and got down the street and smoke started pouring from the tailpipe and the car died. I restarted it w/ no problem and got it back home smoking all the way. I lifted the hood and started it back up and noticed little puffs of smoke coming from under the engine on the left side and still pouring out the back. I checked the dipstick and it said it was way overfilled, so I emptied some of the oil out from the oilpan. When I started it back up again there is hardly any smoke (but still enough) and now the coolant reservoir is boiling after a few minutes of running in idle and my fan won't come on. Does this sound like a gasket leak, dripping coolant into the engine? There was no water in the oil when drained and I did not have any problems with the car before. Is there something I can check or would it be easier to just take it to a shop and bite the bullet?
Old 08-07-2006, 10:06 AM
BMW320i's Avatar
BMW320i BMW320i is offline
Send a message via MSN to BMW320i
Re: 98 escort zx2 smoke from engine and tailpipe
The smoke is white right? You more than likely have a bad head gasket. THe water appears to be boiling since a cylinder is leaking into it building pressure. This is not related to the oil unless oil is getting into the water. It will appear grey and slimy.
Old 08-07-2006, 11:34 PM
Cool Re: 98 escort zx2 smoke from engine and tailpipe
Yeah the smoke is white. How much does changing a head gasket usually cost? Thanks for the help
Old 08-08-2006, 02:23 AM
BMW320i's Avatar
Those cars are pretty easy to do a head gasket on. Call some shops and get prices. Just tell them you want the price for a new gasket installed parts and labor. How many miles on the car.
1998 Lincoln Navigator
1988 BMW 320i (german) 1997 Lincoln Mark VIII
2004 Suzuki GS500F 1984 Honda V45 Sabre
1990 VW Golf II (german) 1994 Lincoln TC
Mechanic on the Army STRYKER
Old 08-08-2006, 02:14 PM
Smile Re: 98 escort zx2 smoke from engine and tailpipe
The car has 137,956 miles. I called 4 shops and the lowest price I got was $480, but that still sounds kind of high. Is that a good price, or should I search around some more?
Old 08-08-2006, 02:38 PM
BMW320i's Avatar
That does not sound to bad to me. If my car ran good before I would pay that. I will check tomorrow and see how many labor hours are listed for that job. Parts prob run at least $100. Make sure you get some kind of guarantee though. Anyone can slap a head on but you need to make sure the shop does the necesarry checks to make sure the head is still good. Prob is but if it is not it will just blow agian. You can also ask the shops how many hours the book calls for. This is what they charge by times the hourly rate they have. Plus parts.
