Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 08-06-2006, 05:52 PM
gaboi68 gaboi68 is offline
water pump bolts
I own a 91 caprice 350, I was replacing the water pump and noticed that the new (wp) didnt have the bolt to mount the fan clutch. How would i go about removing them from the old (wp) and placing them in the new one.
Old 08-06-2006, 07:07 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: water pump bolts
There aren't bolts shipped with any water pumps. If you're talking the fan clutch to water pump mounting bolts, you can use a pair of Vise Grips or some Channellocks to remove the studs from the old pump and put them on the new. Or, you can get a stud kit for cheap and use new studs/nuts.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 08-07-2006, 08:43 PM
TommySS TommySS is offline
I've always used the double-nut technique when I change water pump studs.
Old 08-08-2006, 04:35 AM
Supergumby's Avatar
Supergumby Supergumby is offline
The double-nut method works for me.....
