Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 08-06-2006, 04:34 PM
buckchuck27 buckchuck27 is offline
Send a message via AIM to buckchuck27
radiator fan
i dont kno if everyone saw this in my other post but my radiator fan will not shut off and i cant figure it out. it goes on once the key is turned and shuts off about 10 seconds after the key is taken out. whats goin on?
Old 08-07-2006, 12:25 AM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
Re: radiator fan
it is f-ing hot that is what!!! people keep coming and asking me the same thing at work. the only other thing that can be wrong is the fan relay/switch went bad. if it is 100 degrees there like it is here, then it is going to happen.
go and try picking up some "water wetter" or other form of antifreeze improver. they can help keep those temperatures down.
if your thermostat is bad, then it might just do it all the time to keep things cool b/c it doesn't kno how hot it is, but the likely hood of that is slim.
Don't act like you don't love it.
503/2000
Old 08-07-2006, 09:28 AM
Re: radiator fan
the engine doesnt have to be hot for my fan to come on. if i start my car up after days of it just sitting there, not bein used, the fan will still come on. and i checked the relay in the fuse box under the hood and it works fine.
Old 08-07-2006, 09:40 AM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
Re: radiator fan
Also, if you are running your AC your fan will run almost all the time no matter what the temp is.
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 08-08-2006, 12:06 AM
Sleepr awd's Avatar
Re: radiator fan
that too... it has to get air through the condenser for the a/c to work
503/2000
Old 08-09-2006, 04:29 PM
Re: radiator fan
some good news, the fan somehow fixed itself. i got in my car today and started it up and i didnt here it running so i opened the hood and it looks like its working fine now.
