Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 08-06-2006, 01:24 PM
Mathew420 Mathew420 is offline
How do I replace my starter?
Can anyone please help me on how to replace my starter? Or should I say take it out? Also can just the cellanoid be replaced or is it better to just replace the cellanoid and starter? Thanks for reading.
Mat
Old 08-06-2006, 02:05 PM
Re: How do I replace my starter?
oh yah its a 1997 dodge neon!
Old 08-06-2006, 03:41 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
REMOVAL
(1) Disconnect battery negative cable
(2) Raise vehicle.
(3) Vehicles equipped with A/C:
(3a) Using a floor jack or jack stand, support the engine and transmission assembly so they will not rotate.
(3b) Remove the front engine mount bolt from the insulator and front crossmember mounting bracket
(3c) Lower the front of the engine, rotate the engine forward, allowing easier removal of starter motor.
(4) For easier servicing, do not remove the wiring from starter at this time.
(5) Remove two bolts attaching starter to transmission housing
(6) Remove starter/starter solenoid assembly from transmission housing. Position the starter to gain access to the wiring connectors.
(7) Remove the battery positive cable nut and remove the battery positive and generator output wire from the starter
(8) Disconnect push-on solenoid connector
(9) Position the starter vertically such that the pinion end faces downward.
(10) Remove the starter through the bottom of the vehicle. Move aside A/C plumbing as necessary.
I think you have to replace the whole starter and not just the solenoid, but I am not positive.
Old 08-06-2006, 10:18 PM
thank you soooo much. how do you know this anyway? have you done it before? is it the same procedure with every car or what?
thanks again
mat.
Old 08-07-2006, 02:46 AM
wnt2rd wnt2rd is offline
Das, you're so nice. I would have just recommended the Haynes manual.
That's what I use.
Old 08-07-2006, 09:34 AM
Done it before and it's not exactly the same with every car, but should be similiar.
Old 08-07-2006, 12:16 PM
thanks alot im cheap n wouldnt have bought it hehe. i looked on google to see if anyone knew step by step how to do it (with a neon) and was very suprised to find nothing. thanks das
