Old 08-06-2006, 01:40 PM
buick24 buick24 is offline
Question door pannel removal
I just noticed today on my 95 lesabre that the door pannel pulls out when you grab on from the inside to shut the door. After investigating by pulling out the little ash tray there is not bolt holding the pannel (arm rest) to the metal arm rest that is on the door itself. I checked the other one to confirm that there is suppose to be a bolt there. So how do i get the door pannel off to put a new bolt in there so i dont' reck the interior door panel. It is the passenger side rear door. thanks
Old 08-06-2006, 03:34 PM
grcore grcore is offline
Re: door pannel removal
I am assuming this is the passenger door?
There are screws under the window control (pry out) and behind the reflector (on the edge of door on the latch side).
Old 08-06-2006, 04:22 PM
Yes it is the rear passenger side door. I think that i should be able to get it. Are there any of those plastic clips holding the door in? thanks
Old 08-06-2006, 04:46 PM
yes there are plastic clips, on the lower half. what i posted above should be accurate
Old 08-06-2006, 04:53 PM
thanks
Old 08-06-2006, 11:16 PM
I took the light off the panel and the window controler to find that where the panel is suppose to be bolted to the door there were no bolts. All 3 of them were missing like they were never put in. So hopefully i can find some at autozone tomorrow and fix my door before someone pulls on it and breaks the whole panel off.
