Old 08-18-2002, 12:52 PM
4 door sir2 4 door sir2 is offline
Unhappy important ECU CODE 9
I just put a B16a Sir2 into my 97 ex 4 door and i dont think im getting the full 150 hp to the wheels im pulling an ecu check code its # 9 CYP sensor could this be the problem. When the light is on my car runs terrible and i turn on the a/c my car boggs big time on take off and after
take off i should have 170 or 168 to my fly wheel and i dont think im getting even 100 do u think this sensor could be the problem
If it is how can i go about trouble shooting it
I APPRECIATE ALL THE HELP I CAN GET THANKS GUYS
*4 door racer*
Old 08-21-2002, 05:46 PM
88_SC_CRX_Si 88_SC_CRX_Si is offline
Most likely thats whats causing it. The ECU is in limp mode, because it does not know where the piston is at, in the No. 1 Cylinder. Which it uses as the base, for the Sequential Injection.
"Noth'in like Induction..."
-Ryan-
88' CRX Si - JRSC @ 6psi Z6 Mini-Me, JDM SiR Conversion
NOS #5122, JR Liquid InterCooling System
ZYDNE SECU, 450's
B&M FP Set, B&M Command Flo
AutoMeter - Phantom FP, A/F, N2O, Boost gauges & pods,
ARP HSKit, AEM Pads, 87' HF Drums, DYI CAI
Old 08-26-2002, 10:48 AM
91civicDXdude's Avatar
that could also mean that the engine is horribly out of time. Check your crank/camshaft timing as well as your ignition tming and it should make the problem go away. If not, you may have to replace the distributor as the CPS is located inside the distributor.
