Whatup. Here's a pretty n00b question. I'm new to the V8 scene and am thinking about building a 350 small block. Could anyone give me a list of common cars/trucks that were produced with small block 350s with 4 bolt main from the factory? Then I'll know where to start lookin for a block at the 'yard? Thanks alot.
Re: OEM issued 350 small blocks?
There are Thousands of cars and trucks with a 350 in them. Decide if you have to pass smog, and if you want carb, fuel injected, TBI, TPI, or a LT1 350, or a LS1 350. There is tons of them.
95 Z71 Silverado 4x4 ext. cab Mods- Flowmaster Exhaust,Intake |
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart. Mods: Weight reduction (I don't wear underwear) |
i know the ls1 is a 346 but every one calls it a 350 and i is considerd a 350
if your looking to build just a mild 350, you dont need a 4 bolt, a 2 bolt will work fine
Formerly Blownalcoholboy 1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi) Best ET 1/4: 8.35 @ 170mph (275 drag radial) Best ET 1/8: 5.44 @ 132mph (275 drag radial) Best 60': 1.31 on the back tires (275 drag radial) AF User Rules/Guidelines http://www.automotiveforums.com/vbul...uidelines.html |
All Chevy trucks (that I know of) had 4 bolt mains. The old 3/4ton C20 and the newer 2500 series trucks definitely had 4 bolt mains. The better block to have is the post 1988 blocks that came stock with roller cams/lifters. That way you can have better performance w/rollerization w/o the cost of expensive retrofit roller lifters.
I have 2 1999 Vortec 350 4 bolt blocks that are standard bore and 2 crank/rod/balancer sets for sale if you're interested in building a stroker. I just picked up a '68 Camaro basket case project car. I plan to use a 6 liter LS1 with the MSD ignition system and the Edelbrock carbureted intake. The LS1 has 6 bolt mains, making a great candidate for huge power potential. I agree with Blownalcy, 2 bolt mains are strong enough to handle even impressive power levels. What are your plans/performance expectations? There's plenty of saavy peeps here to give good advice. So let us know what you want to do. |
6 liter LS2, you mean, or are you upping the displacement in the ls1?
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later. 194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies 179.75 RWHP, 204.52 RWTQ ON ITS WAY: MORE R.I.P. Andy 87 Benz 190e - DD 01 EX250 - still gotta get my license for this thing |
Babs, take your temperature... you haven't mentioned a 15,238 CI boosted, injected, sprayed and laid small block yet ...
I do need a 350 block and crank to start building the stroker so send me an email at [email protected] and we'll see if we can work something out. Thanks
My Chevy HD has the 6liter LS1, and that's what I was referring to. The truck blocks have the better performance oriented heads and LQ4 cam for better torque/low end power. It's an iron block oppsed to the Vette/GTO's aluminum LS2 (or am I wrong?) I've heard of the LS6 but haven't researched it, or is that the Z06 engine? One bad dude w/all the titanium internals.
I wasn't sure how to spell savy (saavy/savvy???), anyhow, there's a bunch of smart people that hang out here. |
