water reservoir churning
Just bought a wrecked '98 Escort. I don't know any history on the car but it has been wrecked real light on the drivers side front and the radiator is brand new. Well, the water reservoir is churning a little and this concerns me. I'm thinking maybe it has a blown head gasket and it's pumping compression into the water system. Maybe its something simple. Anybody have any thoughts on this. Thanks.
Re: water reservoir churning
Do a compression test on it. You are prob right though.
Sounds like a head gasket to me. They make a special leak detector that uses a special fluid that will change colors if combustion gasses are detected in the cooling system. SnapOn makes one.
Did a compression test yesterday. 1 and 4 are good but 2 and 3 have very little compression. Found an engine today for cheap, so I might go ahead and fix it because the car is in good shape and I hate to part it out.
I would replace the gasket. If both 2-3 are bad then there is a leak between cylinders. Prob not mixing any water with oil. If the engine otherwise ran good just replace the gasket.
1998 Lincoln Navigator 1988 BMW 320i (german) 1997 Lincoln Mark VIII 2004 Suzuki GS500F 1984 Honda V45 Sabre 1990 VW Golf II (german) 1994 Lincoln TC Mechanic on the Army STRYKER |
Ditto- the time and money in replacing the gasket is far less than a new engine. At the very least get the head off of there and ahve a look at things, drain your oil and see if there is any water in there.
That gasket can be changed in no time. |
