Old 08-05-2006, 11:21 PM
hot_sd hot_sd is offline
Tailgate Lock
For some reason it is becoming harder to close - have to use almost a throwing action to get it to lock properly. Any easy fix or do I need a new lock. If I do any ideas on places/sources to get them. I think the struts are also gone as they no longer spring up easily - could do with a new pair. Not critical to the operaition of the car but the tailgate lock is getting annoying...
Old 08-10-2006, 02:22 PM
idmetro idmetro is offline
Re: Tailgate Lock
Haven't experienced this on mine; yet... However on a different vehicle I have had similar happenings, when I lubed the lock mechanism with WD40 it would work for for another 6 months or so at which point I'd have to lube it again. You might try that.
Old 08-17-2006, 12:56 AM
Re: Tailgate Lock
Thanks for the reply. I did try applying some general purpose grease on the latching lever before posting this but it did not help at all. maybe the WD40 may help - I will see if I can take it out and do something to help the problem.
Old 08-17-2006, 06:34 AM
RossT RossT is offline
Re: Tailgate Lock
try and adjust the bar that the lock latches on to when you shut the hatch. You will need a big phillips scew driver. I had to move mine around a little to get it to close whithout slamming the hatch down.
Old 08-17-2006, 11:03 PM
Re: Tailgate Lock
OK that was a good tip. Had a good look at the lock striker (that's the "official" name for the bar thing) and it was definitely out of alignment at the top. Loosened the screws, realigned it and it appears to have been fixed as it now closes easily and without much effort. Not sure why but many of the screws on my metro cannot be turned by hand - not sure if are using some kind of power tool to put them on at the factory. My impact wrench with an impact screwdriving bit brought it out quick though.
