Go Back   Automotive Forums Car Chat > Chevrolet > Chevelle
Old 08-05-2006, 11:12 PM
joe68 joe68 is offline
motor mounts question
on a68 chevelle, is the front cross member diff. on a six theb a eight cyl?
Old 08-05-2006, 11:32 PM
alblogg's Avatar
alblogg alblogg is offline
Re: motor mounts question
Cross member the same if you are asking about six cylinder motor mounts and V-8 monts. You need to cut the six bangers out and weld the V-8 in.
'99 Blazer LT Loaded, K&N Filter, Pioneer Super
Tuner,Viper
'98 Pontiac Grand Prix GT, 3.8
'88 K1500 Cheyenne, 5.0, stock, bought new
'86 Nissan 720 Trash Truck
'69 C/10 step side, 307, all original, second owner, in process of restore.
The person who says it cannot be done should not interrurt the person doing it.
Share your knowledge. It is a way to achieve immortality.
Allen- Paintman
Wrenchtwister
Broompusher
Old 08-06-2006, 10:47 AM
i currently have a 307 and plans are for a 350, but while under the car last night i notice the engine mounts where off center of the cross member.
is it because of the 307 being a later year motor? off center in sence that not all the bolts are are on the crossmember. will the 350 put in back in the right position? : center" ? what a quick way to tell a 307 from a 350?
thanks
Old 08-06-2006, 12:53 PM
alblogg's Avatar
When you whack off or take off the 307 which ever one you have to do mounts things should start to look right. If they unbolt and the 350 bolt back good but if someone has been there and done some mods before, you might have to cut the 307 off and weld the 350 on.
The motor IDs are located on the front of the block right under head. Sitting in car left head, looking under hood right head. If the alt. and stuff is still on in most cars you can't see it any way but if it is out of car and you have a rag and some WD-40 you can clean it up. Look up your code.
Tuner,Viper
Allen- Paintman
Wrenchtwister
Broompusher
Old 08-06-2006, 01:32 PM
well i can tell you this they are not welded in now or did they bucher anything up from what i can tell,i have some pictures but can't figure out are to attach them. could i e-mail them to you?
thanks joe
Old 08-06-2006, 02:46 PM
alblogg's Avatar
Sure. [email protected]
Tuner,Viper
Allen- Paintman
Wrenchtwister
Broompusher
Old 08-06-2006, 08:19 PM
mdcamaro mdcamaro is offline
Your 307 mounts should work fine for a 350. I used the same mounts for a original 283, swapped in a 327, and 350 in the same car.
Old 08-06-2006, 10:34 PM
alblogg's Avatar
By what I could tell of the pictures you sent me every thing should work fine and the 350 should drop in no problems. By the way I want to tell you joe that is one fine looking machine and I have a buddy that would love to have it (can't wait to show him the pictures). He had a '68 back in his younger days and your's will bring back the goo ole days.
Tuner,Viper
Allen- Paintman
Wrenchtwister
Broompusher
Old 08-07-2006, 10:54 PM
thanks for looking at the picture.can you tell me why i don;t have numbers on the front left head bank? the last car i switch from a 283 to 350 and had no problems. but something did't look right here. thanks for the complient,
i will sent a better picture tommorrow.
joe
Old 08-07-2006, 11:05 PM
alblogg's Avatar
Don't have no reason why unless it is out of a stolen car and the numbers was grounded off so it could not be traced.
Tuner,Viper
Allen- Paintman
Wrenchtwister
Broompusher
Old 08-08-2006, 05:22 PM
ACLineman ACLineman is offline
They BOLT on the crossmember
www.CarolinaSkiffOwner.com
www.ChevyThunder.net
There's a Storm brewing....
Old 08-08-2006, 05:28 PM
If you are talking about the stamped number on the block on the right cylinder bank where the head bolts on. They are removed a lot of time during a re-decking of the block.
Also I used 350 mounts when I installed the 396 into my 69 chevelle , no issue's. The 307 mounts are taller then the 350's and if you have air cleaner to hood clearence issue you may want to be careful. I've heard tale of guys doing this swap, slamming the hood and winding up with a big upside dent in there hood....
Old 08-09-2006, 10:30 PM
thanks for the info, i have a story about something like that, the guys helping me put my 350 in the last cars , forgot to the washer on the bolts for hinge on the hood, and well he crank it and put a big dimple in you know where
Old 08-09-2006, 10:32 PM
thanks that what i need to hear. do you remember if the 327 mounts where in center of crossmember?
