programming keyless on an '05 Cobalt
Does anyone have the procedure on programming remotes on an 2005 Cobalt?
Thanks in advance
"What in the wide, wide world of sports is a go'in on here?" - Taggert |
Re: programming keyless on an '05 Cobalt
If I remember, according to the owners manual you have to take it to the dealer. It can't be done by the owner.
Yep, they get their $30-50 out of you for about five minutes work.
'99 Blazer LT Loaded, K&N Filter, Pioneer Super Tuner,Viper '98 Pontiac Grand Prix GT, 3.8 '88 K1500 Cheyenne, 5.0, stock, bought new '86 Nissan 720 Trash Truck '69 C/10 step side, 307, all original, second owner, in process of restore. The person who says it cannot be done should not interrurt the person doing it. Share your knowledge. It is a way to achieve immortality. Allen- Paintman Wrenchtwister Broompusher |
Thanks for the input...............you can always hope.
"they" don't just get paid for how fast they can do a job, but for the knowledge of how to do it.
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle. |
FYI, programming a key fob takes 5 minutes and can be done by the owner, they just need to know the procedure. I might get it at work tomorrow
"All right Ramblers, let's get ramblin." |
Transmitter Programming
Important: Up to 4 transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle. The order in which the transmitters are programmed is important. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. Use care to program the transmitters correctly. The scan tool must stay connected until all of the transmitters are programmed. Invalidate All This procedure will erase all key fobs from memory. Install a scan tool. Turn ON the ignition with the engine OFF. With the scan tool, select Body and Accessories. Select Keyless Entry. Select Module Setup. Select BCM. Select Program Key Fobs. Select Invalidate All. Follow the scan tool on screen instructions. Remove the scan tool. Exit the vehicle. Operate all functions on transmitters to verify correct system operation. Next Available Slot Incremental programming allows for a transmitter to be reprogrammed into the next available location without affecting the currently programmed transmitters. Previously programmed transmitters will not be erased during this procedure. Important: If all 4 slots are programmed, the Invalidate All procedure will need to be performed to allow transmitter programming. Install a scan tool. Turn ON the ignition with the engine OFF. With the scan tool, select Body and Accessories. Select Keyless Entry. Select Module Setup. Select BCM. Select Program Key Fobs. Select Next Available Slot. Follow the scan tool on screen instructions. Remove the scan tool. Exit the vehicle. Operate all functions on transmitters to verify correct system operation.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again? Got all the certifications 25 years ASE Certified Master Technician GM WCT Yea..I work at a DEALERSHIP....got a problem with that? Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality) This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video PM Me for details |
I was shown a way to program Key Fobs without the scan tool. It calls for the Tech2 on the 2006 monte carlos but all you have to do is goto the DIC and select PROGRAM KEY FOBS and hold lock and unlock.
