Old 08-05-2006, 05:24 PM
Dyno247365's Avatar
Dyno247365 Dyno247365 is offline
Can't dc the TV cable
I easily disconnected the throttle cable that the mechanic cut off at the junkyard, and I could see what it was attached too but even after lowering the transmission like a foot I can't remove it. How do I remove the TV cable from the intake? What's the procedure?
Also... I think the fluid lines are welded to the bolts so...why me, but I may cut them, just as the mechanic did and reattach them with a pressure fitting when I get the new tranny in. Probably will be a lot easier.
1996 Dodge Ram 1500 5.2L 5spd!!!
1987 Chevy Iroc-Z- -Needs a new cat
1992 Nissan 240sx 5spd- SOLD
Old 08-06-2006, 12:32 AM
TEXAS-HOTROD TEXAS-HOTROD is offline
Re: Can't dc the TV cable
I hate it when the nuts get stuck.
An actual line wrench is a good thing to have if you don't have one. vice-grips tend to chew things up, so don't use one unless you have to. I have gone as far as heating the fittings w/a small cutting torch to berak them loose.
If you have a long extension you can use it like a big punch. Hit the extension w/a hammer to smack the fitting and see if it comes loose w/a line wrench.
Don't cut the tubes, I never have cared for the compression fittings. No use risking a blown cooler line.
One more thought. When the old tranny is out of the way. Squirt 2 cans of cooler flush through the system. You'll be surprised of all the trash that comes out.
Old 08-06-2006, 11:12 AM
Dyno247365's Avatar
I did it, while I was trying to figure out how to remove the throttle body, I snapped the TV cable off the TB and it was loose, but I still couldn't get it out from the mounting bracket. So the I remembered something, the little plastic piece comes loose when the wire is loose inside the cable, and bingo it popped out from the trans case.
I'm trying to find a line wrench, or some kind of offset wrench to use because there's not enough clearance between the trans and the floor pan to get the leverage we need.
