Gapping Plugs
Hey Guys, I recently tuned up my 96 tahoe and a friend/mechanic suggested that I gap the plugs at around 56/57 as opposed to the .60 that it should be. Is this a common practice? I have noticed that since I changed my fuel pump it wasn't running that great and my gas mileage was greatly reduced. I decided to tune it up plugs, wires, pcv, air filter, and cap and rotor. This made it run a little better. When the motor is warmed up, it doesn't want to start right away and at least once a week I get a SES P0300 misfire code.
Number 1, should I regap the plugs to the recommended .60 or should I leave them alone? And number 2, any thoughts on the bad gas mileage and difficulty starting when warm? Thanks in advance. Ed |
Re: Gapping Plugs
Hard starting when warm and bad fuel mileage sounds more like a bad fuel pressure regulator. The diaphram leaks sucking raw fuel into the intake. Do a fuel pressure test and watch the pressure after the engine is off. It should hold pressure. I have seen a bad regulator cause the pressure to drop to zero in a few minutes. Do a search on fuel pressure regulator in the C/K forum and you will see more posts on the subject. //2000CAYukon |
Re: Gapping Plugs
Thanks 2000CAYukon. I hear that replacing the fuel pressure regulator is a real pain. I understand from reading on this forum that you have to take the intake manifold off. How difficult is this?
And also, how do you check your fuel pressure? Is there a port or something where you put a guage? |
Re: Gapping Plugs
There is a test port on the fuel rail where you can hook up a fuel pressure gauge. IIRC, it is on the drivers side fuel line going to the intake. There is a dust cap on the test port that you need to remove to hook up the fuel gauge. //2000CAYukon |
Re: Gapping Plugs
Ed |
Re: Gapping Plugs
GM does have problems with the distibitor gears for the vortec engines and most auto parts stores,dealers stock the distribitor gear.It might be a worn out distribitor gear and it will cause a miss.I went through this and and it was a distribitor gear after finding out replacing the plugs was not the problem.Mark the distribitor before pulling out and the timing is not adjustable.The distribitor is set with a scan tool,+ or _ 0 degrees.Where did you get the plug wires?Cheap plug wires will do it too,ones from AutoZone and Advanced.Cheap parts are not the way to go.
Re: Gapping Plugs
The problem started the day the pump went out. I replaced the pump with one from the dealer. The truck ran great up until then so I thought maybe I did something wrong while installing. Come to find out the plastic fuel lines were bent in half so I dropped the tank again and replaced the lines that go to the pump. I never checked the line at the front of the tank. What is the purpose of that line? Is it a return? I thought the smaller diameter line that connected to the sending unit was the return. Any way I dropped the tank again last weekend and discovered that I was pinching the fuel lines again so I fixed that but I still have the problem. |
Re: Gapping Plugs
If you want to get a new set of plugwires,Carquest sells high quality plug wires and I have been having very good luck with them and with no comebacks.I know Ac Delco plug wires are expensive and are very good I have been hearing
