Old 08-05-2006, 12:27 PM
cory fincher cory fincher is offline
car not starting
hey guys my 92 1.9l is haveing starting issues it will start some times and others not it has power cause it will bump start but some times it acts like i am not pushing in the cluth so when i turn the key nothing any help would be great i thought it might be a clutch safety swith malfunction if anyone knows how to dissconect tha let me know
Old 08-07-2006, 10:11 AM
BMW320i's Avatar
BMW320i BMW320i is offline
Send a message via MSN to BMW320i
Re: car not starting
Yeah, My 95 had this problem. It is usually illegal to tell someone how to disengage a safety device. The sensor is on the pedal somewhere and attached to the firewall. It should be like the brake light switch. I would clean it first. Spray wd-40 or elevtric clean on it. Push harder on the clutch. I just had to push harder on mine to fix it.
Old 08-12-2006, 07:46 PM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
One time when one of my batteries was going dead I kept having a problem like that. Sometimes the car would start fine, other times there would be power through the first couple clicks and then when I turn the last click to start it was dead... NOTHING.
All I had to do was get out and jiggle the positive lead on the battery a little bit and all was well.
As soon as I got around to replacing the battery I neer had the problem again.
Old 08-14-2006, 03:54 AM
hakachukai hakachukai is offline
When you have problmes starting, put you head lights on high beam.
If your head lights get very dim when you try to start the car, you have a power issue. (as in bad battery, or bad battery connection)
If they stay nice an bright the whole time, you have plenty of power but it's not getting to the starter for some reason.
It's also possible that you have plenty of power, and that it is getting to the starter, but the starter it bad.
