Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 08-05-2006, 12:00 PM
KaMaKaZiPyRo KaMaKaZiPyRo is offline
Send a message via AIM to KaMaKaZiPyRo
82 Cruiser Problems
My car stalled out, a wile ago i tried to start it after it didnt run for a couple weeks and i had to tap the starter for it to get going. Then after that when i would drive around it would just turn off for a quick second like it died then start back up again before i had time to take my foot off the gas. Now it wont start at all, when i turn the key its completely nothing, no turning over, no cranking. Anyone have any ideas?
Currently trying to piece together a Turbo CrVtec bubble hatch, expecting sumthin like 500hp?!?!?!
Old 08-05-2006, 04:13 PM
maxwedge maxwedge is offline
A990 racer
Re: 82 Cruiser Problems
In the future post the model and engine, anyway check all the battery and ground connections first.
Old 08-08-2006, 03:12 PM
O im sorry im not really too sure, i just barely got the car a lil bit ago. Im not too familiar with oldsmobile, or really anything besides a 4 cylinder. But neway, i know its a v8 and i got under the car and wired it directly to the starter and nothing. Is there any thing specific i should check for?
Old 08-08-2006, 03:42 PM
A990 racer
Exclamation Re: 82 Cruiser Problems
Your post is vague at best! As mentioned, focus on battery condition, connections is there 12v to purple wire on solenoid when cranking, get help here if required.
Old 08-18-2006, 02:57 PM
Well, while trying to find out the problem of th vehicle, I ran into a couple of things. One, there is an exhaust pipe in the way of the starter, it was a bitch trying to get it out. So i remove the starter and the solenoid whole, took it to autozone and they tested it. positive. So i try to replace the starter and I had to part it in there,starter then the solenoid. So I turn the key and still nothing, no cranking at all, no turn over. I checked for the battery drainage and the lights work, the CEL is on, and the oil light showin. But no sound when i turn the key. Does anyone know of any ideas of what to check for next?
Old 08-18-2006, 07:03 PM
A990 racer
Lightbulb Re: 82 Cruiser Problems
How about my previous suggestion about 12v on the purple wire to the starter, when trying to start, is it there? Are the fusible links coming off the starter harness intact? You really sound like you need on site help with this to properly check these circuits, no car alarm/cutoff right?
Old 08-18-2006, 08:04 PM
Im going to look for the purple wire. Also the starter(silver part) the gold bolt coming out of it, that conects to the battery is lose from the starter, it moves in and out.
