Old 08-05-2006, 12:42 AM
03silveradoaby 03silveradoaby is offline
Possible Wheel Bearing Issue. Questions
I have a 95 blazer, 4x4. What my question is recently over the last few days it has developed a grinding sound in the front end, vibration and noise only coming from the passenger side. The thing that is confusing me is that with most bearings if they're bad they make noise till you fix em. This noise only occurs when turning left or right. Any suggestions? Lower balls are brand new moogs and uppers are getting done this weekend i grease the piss outta this truck Any and all help would be great thanks. Also i have been looking, can i just replace the bearings or do i need to do the whole hub assembly?
2003 Silverado 4.8
10k HID low beam/6k HID highs
magnaflow exhaust
k&n intake
2/10 rockford p3 shallows, downfire box, 1800w kenwood amp oversized battery and alternator hawk brakes
22" Forte miami's with Cooper zeon xst 305/40/22
Old 08-05-2006, 06:27 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Possible Wheel Bearing Issue. Questions
Could be bearings or CV joint(s).... Jack the front of the truck up, have someone grab the wheel at 3 and 9 o'clock and rock it back and fourth and 6 and 12 o'clock and rock it. While they're doing this, stick you head behind the wheel and look at the back of the hub to see if there is any play. If there is it's the hub, if not, look to your cv joints.
Old 08-05-2006, 03:45 PM
BlazinMlew's Avatar
BlazinMlew BlazinMlew is offline
Send a message via Yahoo to BlazinMlew
I am not sure on your 95 but on my 2000 you cannot replace/regrease the bearings. It comes as an entire hub assembly, but like I said I dont know if it is the same for your 95
2000 Blazer 4WD 2Door
http://www.cardomain.com/ride/2324297
06 Pontiac G6 V6 Coupe
http://www.cardomain.com/ride/2371527
Old 08-05-2006, 08:15 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Push your dust shields back by putting your thumbs at 5 and 7 o'clock and push them back.
Then go get your tires balanced.
1995 Factory Blazer Service Manual for sale, PM if interested.
