Old 08-04-2006, 10:37 PM
flaming_blades flaming_blades is offline
94 grand am stereo help!!
hi, does anyone know how to remove the stereo from a 94 grand am? i cant seem to figure it out.
thanks!
Old 08-05-2006, 12:55 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: 94 grand am stereo help!!
First disconnect the battery(if your removing the radio)
Remove the bezel and any other trim pieces to gain access to the retaining screws around the radio.
Should pop off with a panel tool or a straightslot screwdriver, thiers just clips holding it on.
Unscrew the screws holding in the radio, pull the radio out, detach the connectors, ground cable and antenna, then remove the radio.
Hope that helps,
And Welcome to AF !
1999 Grand Am SS 3.4 OHV
Old 08-05-2006, 05:27 PM
skibum1111 skibum1111 is offline
Send a message via AIM to skibum1111 Send a message via Yahoo to skibum1111
Ok I'm going to get a little more detailed. Remove the cup holder. Remove the plastic panel under the dash on the driver's side. Remove the dash vents in the center of the dash. Remove the glove box. Remove the trim around the radio. There are 2 nuts above the radio, remove them, the radio should slide out. Good luck, when I took mine out it involved alot of bad lanugage until I found all the screws. Some are torx, some are phillips.
Rusting out Honda Civic $900
Fart cannon muffler: $300
Assorted stickers advertising products you'll never own: $50
Having your @ss handed to you by a brick shaped suv: Priceless.
Yup, I own the suv.
