Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 08-04-2006, 10:08 PM
TeamRedLine23's Avatar
TeamRedLine23 TeamRedLine23 is offline
Send a message via AIM to TeamRedLine23
Greddy Boost Controller Question
I installed my greddy boost controller today. I set the controller at 14psi(hi). The thing is on my boost gauge and on the contoller it maxes out at 12psi. i was woundering about the way I installed it. The boost gauge and boost controller are both hooked up to the same fpr line. would this have anything to do with it? thanks
what i ment to say is it ok to have both the boost gauge and boost controller running off one line.
1997 Eclipse GS-T
Performance modification:-evo3 16g-K&N Intake-HKS SSQV b.o.v vented-2.5'' Dejon tool blow thru upper and lower-Dejon large smic-GM MAF-MAF Translator-HKS 3" Carbon Fiber Titanium TBE-stock fuel rail-Walbro 190 fuel pump-PE 650cc injectors-Accel Thundersport wires-NGK series 7 spark plugs-1g intake mani/head-
Interior Modification:-Autometer Boost Gauge
http://www.cardomain.com/id/xTeamRedLine23x
Old 08-07-2006, 04:30 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Greddy Boost Controller Question
I wouldn't run a boost controller (or anything if possible) on the FPR line. Any leak on that line will cause you to run lean, so it's best to keep it a solid run of high quality vacuum line.
About your specific problem, I don't think using the FPR line has anything to do with it. You should start by posting which of the Greddy EBCs you are using, since there are at least 4 different ones (A, B, spec 2, type s). I have a feeling that this is a spec II based on your wording, and I have experience with the old skool B and the newer type s.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 08-07-2006, 05:13 PM
sorry about that its a profec b-spec2. what line do you recommend for hooking up the boost controller to? as for the boost gauge, the fpr is ok for that, if no where? thanks a lot
1997 Eclipse GS-T
Old 08-07-2006, 07:59 PM
AF - Advisor
You are on your own with that steaming pile of donkey biscuits
The best place to tap into is the BOV line, the P port on the TB, or a fitting that you add yourself. Losing any of those things would not be catastrophic.
Kevin Jewer
Old 08-07-2006, 08:48 PM
so leave the boost gauge tapped into the fpr and tap the boost controller into the b.o.v. line?
1997 Eclipse GS-T
Old 08-07-2006, 09:37 PM
AF - Advisor
Kevin Jewer
