rear brake cost
the rear calipers on my 92 continental rusted to the point where they were frozen together...the brakes are gonna need to be replaced along with the e-brake cable which rusted out. the mechanic quoted a price of around $900 for both things to be fixed. does this sound right to anyone? it sounds too high to me.
Re: rear brake cost
That's around $20 for loaded calipers (loaded w/shit pads) and the rest goes for whatever machining is needed to the rotors and labor. If the rotors are replaced rather than machined, they'll most likely use the cheap-shit chineese ones (brand new) and raise the price to around $120 per wheel.The brake cable is another story. I'm thinking $30/$60 new plus labor IF there's no damage to the car at the cables' mounting points. Add 200% of the parts cost on this job to calculate labor. ($60 parts = $120 labor) They'll deny the formula bt like I said, it depends on the job. I can see this getting up toward $700~$800 at a shop for ALL FOUR wheels, including the brake cable. If you wanted to DIY, I figure around $400 in parts (all four loaded calipers, all four premium rotors, and the cable). The cable might prove to be a PITA depending on which piece is replaced. On some fords the rear axels have to be pulled to get to that end of the crossover cable.
-Steven 1996 Town Car, Cartier |
thank you very much...like i said its gonna be $900 for just the rear ones plus the cable for my 92 continental..this is from monore muffler here in upstate ny. not a dealership...so yea i figured that it was a little high myself.....it also needs an exhaust from the catalytic converter back thats like $1300 which i can understand casue its dual....plus one final thing the oil pressure display keeps on registering low pressure. this happens intermittently and it shows one bar and flashes and the chime goes off...it happens for a minute or so at the most and when done the pressure goes back to the normal range. while this is happening the car is otherwise fine. it just had an oil change a week ago.
Re: rear brake cost
The Oil Pressure sensor is the most likely cause for your other problem. Sometimes its just a loose connection, but usually it's the sensor going out. It's less than $10 for the sensor, and easy to change if you have some basic mechanical skills and tools.
Re: rear brake cost
well i dont have a latino owned shop to go to to spend 250....which leads me to wonder about the quality of the work in any event...hows it been holding up for you? yea thats what i figured about the oil pressure...try telling heritage lincoln mercury that....theyre a local dealer in syracuse, ny....but i digress...
Re: rear brake cost
Wish there was a cheaper way for you out there in NY.
Re: rear brake cost
You can easily replace the rotors and pads, etc yourself. It is very simple and you normaly do not need many tools. You might need one special tool depending on what holds the caliper on. Usually it is a torques or allen bolt. You remove the wheel and then you find the two bolts that hold the calipers on. THe heads point towards the inside of the vehicle. You take both out then remove the caliper and the pads just pop off. The rotor then falls off by itself. It might have a small screw in it just to hold it in place but usually not. You can then use a c-clamp to compress the caliper and put the new pads in but if you are replacing them just take off the brake line and install the new ones the exact opposite. Parts prob cost in the area of $300 if you are doing pads, rotors, and calipers. You can check prices at www.schucks.com also just get cheap rotors for the rear they don't do enough braking to get hot and warp. Also Replace rotors don't machine them unless new ones are just extremely expensive. When you machine them they warp even easier. The cost usually is around the same for either way.
Re: rear brake cost
when you C-Clamp our caliper pistons, all the newer ones screw in, the c-clamp will just punch a hole in the piston.
Re: rear brake cost
I have only seen the screw in calipers on a Ford Taurus and similiar Fords. Do you know for sure of the Continental have the screw in ones or not. It would be pretty hard to punch a hole in one. Image the pressure they apply to the discs. You think you can just c-clamp a hole in it? OK.
Re: rear brake cost
Let's apply some basic physics here: 1) The piston uses it's entire surface to push against the pad, forces are spread out over the entire surface. 2) The c-clamp uses a 1/2" to 3/4" 'foot' applying pressure to the thinnest part on the surface of the piston. I won't take a genius to figure out what's going to happen if that piston dosn't move, and more pressure is added to that pressure point. My 1996 pistons screw in. AS FOR YOUR PERSONAL ATTACK TO MY EMAIL AND THESE VEHICLES: Quote:
GET OUT OF HERE IF YOU CAN'T HANDLE BEING CORRECTED EDIT: Sorry folks, anger mamagement relapse.
Re: rear brake cost
I emailed you, this is the correct thing to do. Why post this publicly. You want the attention or what? Take your ego and you leave
1998 Lincoln Navigator 1988 BMW 320i (german) 1997 Lincoln Mark VIII 2004 Suzuki GS500F 1984 Honda V45 Sabre 1990 VW Golf II (german) 1994 Lincoln TC Mechanic on the Army STRYKER |
Re: rear brake cost
Can someone do a Test for us. See if you can punch a hole in a caliper with a c-clamp. Stop when either 1 you bust a hole in it or 2 cannot turn the c-clamp anymore by hand, Then post your results here. I do not have any old ones lying around. And does anyone know for certian if the calipers on the Continental turn in or compress in. Since of the compress in I did not need corrected by Wise Guy up there.
Re: rear brake cost
Look I found a guy that used a c-clamp on a screw in type caliper and what do you know. No hole, his statement is it won't budge.
Can be found athttp://experts.about.com/q/Ford-Repair-811/rear-brake-caliper.htm Please LINCOLN TOWNCAR back up your statement that you can bust a hole in the caliper and that it is indeed a screw in caliper. Or just shut-up. "I'm changing out my rear rotors and pads. The pistons on both sides seem to be fully extended and i cannot contract them into the calipers. I tried using a C-clamp and a specialized tool, but piston would not budge. Please help!!! 97 Ford Mustang V6, no previous brake work.. Thanks, Anthony "
Re: rear brake cost
What a nimrod!! Just whom do you think Steve H is.... Anthony broke through the piston, he was too embarassed to post it there. You weren't even a sperm yet when I was doing 160 across the dry lakes. Change your diaper! BTW, I'm pretty sure the points of this thread are all pretty much covered. Catch ya on the next one fool.
-Steven 1996 Town Car, Cartier Last edited by Towncar; 08-08-2006 at 12:24 AM. |
Re: rear brake cost
160 huh in what your cruiser. And if you are really that old then you should not be posting on things that are out of your field. Go back to your model A. These cars are too advanced for you to understand.
