Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 08-04-2006, 07:00 PM
ajstjohn ajstjohn is offline
Plenum Gasket
I have a 98 bonneville. I have a case of the lost antifreeze. I spoke with a mechanic and he said that it's my plenum gasket. All the antifreeze is leaking into the engine. Can anyone tell me how to replce this on my own?
Old 08-04-2006, 07:46 PM
jdq jdq is offline
Re: Plenum Gasket
What model SE, SLE SSEI
It would be worth it to get a factory service manual if u do it yourself.It isnt to hard if you have time and are pretty good with your hands.I did it on a 90 sse and maybe soon on a 2000 ssei and it was a first time , wasnt too bad.
2000 bonn ssei 155000 klm
1997 dodge caravan 92000 klm
Old 08-04-2006, 11:16 PM
NVmySSE NVmySSE is offline
Re: Plenum Gasket
yea i have a 99 SSE and it did the same thing...sure enough antifreeze in the motor.. but i wished i was smarter and did it myself..if you know what your doing it'll save u big $$$$$$ mine cost just over $600 for the dealer to do it
Old 08-10-2006, 08:02 AM
wlkjr's Avatar
wlkjr wlkjr is offline
Re: Plenum Gasket
I did it on my Grand Prix about two months ago. All parts will be less than $200. There is a good procedure in the GP forum that I followed and I didn't have any trouble. If you have a digital camera it is a good idea to take photos of all the hoses and how they route. My memory is not that good anymore and that helped me a lot as I did the job over a 4 day period. I also got a Sharpie silver marker and labeled all the wiring connectors with an alphabetical labeling system. I would suggest to replace the upper and lower both at the same time since everything will be apart anyway. Mine had over 300K miles on it when it went. I replaced the upper plenum but the old one was not degraded like the ones I have seen.
If you can change a belt, alternator, or waterpump, this is a job you can handle. Just be patient.
97 Grand Prix GT
360,000 miles as of 02-01-09
391 000 miles as of 11-17-11
400,000 miles as of 3-15-13
01 Duramax/Allison
07 G6 convertible
Old 08-10-2006, 05:22 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Plenum Gasket
Your 98 is most likey a bad upper plenum, not just the gasket. The 95-98 VIn-K 3800's had an issue with the EGR stove pipe eroding the plastic manifold and causing coolant to leak into the engine. Buy an improved design plenum (it will come with the upper plenum gasket and throtle body gasket) and a lower intake set and do both while it is down. Wally, I still can't believe how well yours held up with your mileage, you were lucky. Just for reference, the 99-ups have a redesigned plenum that addressed this issue, but the gaskets were still crap.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 08-11-2006, 07:41 AM
wlkjr's Avatar
Re: Plenum Gasket
Surely not all of those year models have had to have gasket replacement done.
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
Old 08-11-2006, 08:23 AM
whitecrystal1's Avatar
whitecrystal1 whitecrystal1 is offline
Re: Plenum Gasket
I have vin #k also and I did my upper at 130k. At that time I didn't do anything else. 50k later it started leaking again. I was told what your saying about the complete kit. It's been 25k miles ago now since it was done the second time. Hopefully it's good now. I still add a very little antifreeze to th car about every 4-6 months. Not a big deal but I did have it pressure tested two different times by a small shop and then the dealer but they couldn't find any leak.Oh well.
That has been the only problem besides the fuel pump that went bad last year and the ac compressor this year. No complaints here.
1999 Bonneville SSEI L67 Dark Caribe Green Metallic 81K
2002 Buick Lesabre Custom L36 Ming Blue Metallic 45K
2010 Silverado Crew Cab LTZ 6.2L Max Black Granite 3K
2001 Wellcraft Martinique 2400 Merc 5.7L BIII 263hrs
1995 SSE L36 Dark Polo Green Metallic **R.I.P. 4/28/10 236,400 miles**
Old 08-11-2006, 09:49 AM
wlkjr's Avatar
Re: Plenum Gasket
Any oil analysis is $20 and should tell if the anti-freeze is getting into the oil.
If I have to spend a thousand a year to keep it running, I figure I'm way ahead in the game.
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
Old 08-11-2006, 12:16 PM
Re: Plenum Gasket
Where would I take the oil to have it tested? and do I have to buy a oil analysis kit to put the oil in for the oil to be tested or would any bottle work?
Thanks
Old 08-11-2006, 12:27 PM
wlkjr's Avatar
Re: Plenum Gasket
Thanks
Go to www.blackstone-labs.com
You can order a free sample bottle and get all the information from the website. I've used them several times with good results. They are slow at times but usually within 10 days you have the results. Costs under $2.00 for shipping, so for about $22 you can get a good idea of what you oil is doing and maybe what's going on with engine wear.
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
Old 08-11-2006, 12:40 PM
Re: Plenum Gasket
Thanks
Old 08-11-2006, 12:49 PM
wlkjr's Avatar
Re: Plenum Gasket
You're welcome. That would be money wisely spent with that mileage.
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
Old 08-14-2006, 04:13 PM
richtazz's Avatar
Re: Plenum Gasket
Wally, in 04, GM finally gave up on the composite intakes and went back to the aluminum one. Every one of these motors will need either a plenum replaced (98-back) or an upper intake gasket replaced (99-03, or possibly a plenum if the gasket was let go too long) sooner or later. Just like the GM 3.1/3.4's, they use crappy gaskets that will fail sooner or later.
