Old 08-04-2006, 04:17 PM
bmx419gt bmx419gt is offline
intake '91
91 escort gt.... what does anyone think would be the best deal for a new intake tube or cold air intake, cause my stock tube has a hole in it. dealer sadi $92 for a new stoc k tube but i think for a few bucks more i might get a aftermarket any ideas???
Old 08-07-2006, 10:14 AM
BMW320i's Avatar
BMW320i BMW320i is offline
Send a message via MSN to BMW320i
Re: intake '91
Where is the hole at between the filter and engine or before the filter and the outside air. I would do nothing if it is not between the engine and filter. If it is between this. Can it be either taped or find one at ebay or a junk yard. All this does it keep dust out of the system. Remember when replacing your filter system your MAF must be kept intact. If it is removed or altered it could cause damage to the engine and will not let it run good.
Old 08-08-2006, 01:57 AM
Davescort97 Davescort97 is offline
Escort guy
Re: intake '91
You can get a replacement from Napa, Auto Zone, or Advance for about $50. When mine developed cracks I sealed it with silicone. Worked good.
Old 08-15-2006, 11:18 PM
Re: intake '91
silicone sounds good. it doesnt start to melt though from the heat? i went to walmart and bought this stuff that is like sticky tape on one side and like aluminum foil on the other i thought it would be best cause iitd reflect heat, but now it is losing its stickiness and i can tell more air is getting in cause itll try to stall out sometimes from too much air and not enough fuel when at a stop
Old 08-16-2006, 01:44 AM
BMW320i's Avatar
Re: intake '91
There is not much heat on a intake tube. Prob less than 100 degress. If you are worried about that get some high temp stuff.
1998 Lincoln Navigator
1988 BMW 320i (german) 1997 Lincoln Mark VIII
2004 Suzuki GS500F 1984 Honda V45 Sabre
1990 VW Golf II (german) 1994 Lincoln TC
Mechanic on the Army STRYKER
