Old 08-04-2006, 04:16 PM
breadeater1 breadeater1 is offline
91' Stealth won't start.
Hi, I did a search on the forum to find an answer but didn't come up with anything so now I'm posting this. My car won't start and I think its the battery but i'm not sure so i'm asking ya'll.
I tried charging it but that didn't work so then i tried to jump start it with another car and it didn't work. When i put the negative cable on the engine block or the ground post it started sparking and when i put it on it got really hot and started to burn a hole so I took them off. After this i gave up and came back a few hours later and the car started up after a bit of hesitation. I ran the car for a few minutes to try to charge up the battery so it would start again then i turned it off, turned it back on and it was good...ran the car for a few more minutes then left.
Now it won't start again! I thought this might be a problem with post/cable connectors not being clean so I took the batter connectors off and cleaned everything to be nice and shiny and put them back on and it still won't start. The dash reads 8V. Do I need a new battery or is this a worse problem?
Old 08-04-2006, 04:24 PM
Igovert500's Avatar
blue + red light magnet
Re: 91' Stealth won't start.
Take it to Autozone, have them test your battery, alternator and starter. (its free)
Also are you getting a clicking noise under the dash from inside the car?
Has the car or battery been sitting for along time?
Did you leave anytihng on that could have drained the battery?
When it works, do you have problems with your lights dimming and stereo getting quieter when idling at a red light. If so, do they get brighter when you rev it up?
Also it helps if you say what model and tranny you have. Maybe not in this post specifically, but the more info the better when you want help on the internet. Welcome to AF.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 08-04-2006, 04:29 PM
I was getting the clicking before but not anymore. Is there anyway I can test the battery, starter, and alternator myself because I can't get the car anywhere now.
Old 08-04-2006, 05:15 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
if you have multimeter (voltmeter) you can test output of the battery.
ur best bet is to remove the battery, have a friend drive you + battery to autozone, have them test it (yes, its free). they'll let you know if it good or not. if good, it may need to be recharged. (recharging takes about 1 hr).
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 08-05-2006, 02:59 AM
AutostradaVR4 AutostradaVR4 is offline
if it didnt start when jumped, i would lean towards starter. Does it turn over? Or does it just 'click'? If it doesent even turn over when jumped, its almost definetely your starter. Try this: Leave the car in gear (DRIVE if its an Auto), and rock it front to back a few times by pushing it. Then try and start it again.
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 08-05-2006, 09:30 AM
Morphius289's Avatar
Morphius289 Morphius289 is offline
If your volt meter thing is below 12, your alternator is almost def. gone. But this sounds more like a starter problem.
Black 1997 3000GT
Originally Posted by Igovert500
[01:05] Igovert500: scrwe his method
[01:05] Igovert500: too much crap
[01:06] Igovert500: i just jam a garden hose in there
[01:06] Igovert500: and put it on high flow
[01:06] Igovert500: go the opposite direction too
[01:06] Igovert500: so it clears out more shit
18 and out of debt - member #1
Old 08-05-2006, 09:35 PM
liquidPunk's Avatar
liquidPunk liquidPunk is offline
Send a message via AIM to liquidPunk
Honestly... This happened to me when i first got my car... It wouldnt jump, and Autozone said the battery was good... but in an attempt to not have to change the alternator I got a new battery anyway... It worked... so I'm not sure how much you can trust the autozone battery tester... anyway.. thats how it went for me!
1992 Mitsu 3000gt sl 5sp
- High flow filter - Pioneer head, dual 10's - H4 headlight conversion
- Throttle Body Spacer - The "For God's sake stop that infernal buzzing" mod
- LED "Snake Eyes" - Lightweight Crank Pulley
-More to come-
Your 3000GT is the 5095th out of 6964 . Only 41exactly identical
Bloody Knuckles from Changing Fuel Filter Crew Member #1
