Old 08-04-2006, 03:31 PM
1991HB 1991HB is offline
Send a message via AIM to 1991HB
master break cylinder
I replaced by master brake cylinder today and now I don't have any brake at all. The brake pedal goes further down than before with the old master cylinder. All I did was take the old one off and put the new one on. Any ideas? Was I suppose to do something else before putting the new one on. Any help would be great...maybe some step by step directions...I don't know anything. Thanks.
Old 08-04-2006, 05:19 PM
Smoghog Smoghog is offline
Re: master break cylinder
Originally Posted by 1991HB
I replaced by master break cylinder today and now I don't have any breaks at all. The break pedal goes further down than before with the old master cylinder. All I did was take the old one off and put the new one on. Any ideas? Was I suppose to do something else before putting the new one on. Any help would be great...maybe some step by step directions...I don't know anything. Thanks.
You have air in the "brake" lines you need to bleed your brakes.
Old 08-04-2006, 06:25 PM
crx2034 crx2034 is offline
yes and i am pretty sure you need 2 people to do this( correct me if i am wrong). I had a freind who bled his own brakes and i was like, there is no way to bleed your brakes by yourself.
Old 08-04-2006, 09:13 PM
Thanks a lot guys...it really helps. I thought I bought a new part and it didn't work. I'm kind of new with this so how exactly would I go about bleeding the brake lines
Old 08-04-2006, 09:41 PM
another quick question I got. There are 2 bolt sticking out of the booster that the master cylinder goes onto. One of the bolts are broke off from someone tightening it to tight. Would it be a big problem if I didn't use that one bolt as long as I have the other one and it's tight. If I do need it can I get it at a part store or something. And how do I get the rest out. There is still a little bit sticking out if I can just use pliars and just screw the rest of it out. Thanks.
Old 08-05-2006, 05:07 AM
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
you can always drill it out and then tap and dye it. but that's just me.
-tony-
2000 honda s2000
Old 08-05-2006, 10:18 AM
Bleed, Two people or a vacuum pump and the correct fitting.
Bolt, You can swap out the brake booster. Other than that the tap thing will work. but alot harder.
Old 08-05-2006, 05:11 PM
yeah if u tap it it will be harder and will take a lot of patience.
-tony-
2000 honda s2000
Old 08-06-2006, 08:41 AM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
My first question for you is did you bench bleed the master cylinder before installing it in your car? This is a VERY important first step and took me about 45 min of pumping to get all the air out of my replacement master cylinder (zero bubbles floating around in the fluid). I also agree a helper is essential for brake bleeding if you don't have a "one man" bleeding gizmo.
I've always bleed brake systems by starting with the farthest wheel from the master cylinder and work your way closer to the master cylinder. (ie. 1. passenger rear, 2. driver rear, 3. passenger front, 4. driver front and always making sure the reservoir is topped off).
If I understand your post, one of the master cylinder mounting studs sticking out of the booster broke off? If there are enough treads left sticking out you can go to the dealer or junkyard and get a replacement nut. But if you can't get a nut on the stud I highly discourage using only one mounting point for your master cylinder. The best solution is replace the booster with a new or reman unit, as disassembling the booster to replace the stud is rather complex, but if funds are short you can get one easily in a junkyard but again these are your brakes, and IMO this is one of those systems you SHOULD NOT skimp on. Please keep us posted. GL
Old 08-13-2006, 04:18 AM
well i got the master cylinder on and everything bleed. I still only have one stud for the master cylinder but I will get that fix soon. I just needed to get the car going. Thanks for all your help guys.
Old 08-13-2006, 11:42 AM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Ive never had a problem bleeding the brakes by myself without one of the gizmos. Granted I'm sure its not 100% bled, but its pretty damn good. That is how I had bled my race car for the fact no one else was around to help and I haven't had a problem out of them yet. Ive also bled a friends race car with only me and I drove his car that week and got his rotors cherry red from how hard I was on them that night. All I ever do is loosen the bleed screw off, pump the brakes until it starts shooting fluid out, and tighten the screw. Even if you don't agree with this, I haven't had an issue and would drive the car on the road like this, and if you want to continue bleeding, this atleast gets most of the air out.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 08-13-2006, 02:02 PM
thefooshmeister thefooshmeister is offline
Send a message via AIM to thefooshmeister
yeah ive done the same thing tony. probly not the best way to do it but hey when youre in a pinch ya gotta do what you can. definately wasnt fun bleedin them by myself, had to use a brick to hold the brake down
98 Jetta GLX VR6-vroom vroom!!
91 CRX Si-R..busted..
Old 08-13-2006, 03:37 PM
Tony's Avatar
TLD Member #1
i didn't even do that, i just pumped it until fluid came out, got out and closed it off, lol. Like I said, its not the best, but if thats all you can do, its a hell of a lot better than leaving it alone, I haven't had to pump the brakes on either car because of air yet, so I'm happy with it.
Tony
Old 08-15-2006, 12:35 PM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
here is a site that you might love to help make everything simple all the time for you
check this out
90 Honda CRX Si
-Red/Black
-B20B/b16
-AEM CAI -/\- Apexi GT Header/2¼" Custom Dynomax Exhaust
-Tein SS CoilOvers with pillow ball monuts -/\- ST Swaybars/Energy Suspension Bushings
-16x7 Lightweight Rotas -/\- Pro Stop Rotors -/\- Goodridge S.S. Brake Lines
-Skunk2 Shifter -/\- MoMo Steering Wheel
Old 08-20-2006, 03:21 PM
ATMDC's Avatar
ATMDC ATMDC is offline
your you can buy aftermarket one way valve brake bleeder screws so you can bleed them yourself. ive never used them so i dont know how good they work.
