Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 08-04-2006, 01:34 PM
spanks spanks is offline
93 88 with 3.8 no start
i'm working on a 93 olds 88 3.8L. Cranks no start. I have power at injectors but no ground same for ignition modual. i changed the crank sensor, cam sensor, ignition modual and pcm but no luck still no spark no pulse.i have checked just about every thing i can think of. can any one please toss me a bone here.
Old 08-08-2006, 05:10 PM
Mickey#1 Mickey#1 is offline
Re: 93 88 with 3.8 no start
Check for power going to the ICM. There should be 12 volts at the pink (pink/black?) wire going to the ICM. It's on one end of the connector. Check with key in run position.
Old 08-09-2006, 07:19 PM
Salestax Salestax is offline
When you turn the key on engine off (KOEO) do you have a check engine light? This should come on for a bulb check. If its not on, check fuses/fusible links. Definatley check for 12v supplies to computer components. If you need a wiring schematic, let me know.
Certified Master Tech
88 Lesabre, 93 Lesabre, 02 Lesabre
74 VW Superbeetle, 70 Maverick
Old 08-09-2006, 10:22 PM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
What about the starter? In any case, I wouldn't throw any more parts at it untill you know what codes it is throwing (and I'm almost certain that it is). If you don't know how I can dig up a link to show you. 93 was still OBD 1 which means that all you need is a paperclip
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 08-11-2006, 04:09 PM
thanks guys but no luck i gave up and it's going to the big junkyard in the sky. i checked every possible option and had a tech with 20yrs exp. check it with me and nothin. so i gotta cut my losses. i really wish i had time to know what it was.
Old 08-11-2006, 11:53 PM
Alibi's Avatar
-Eric
