Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 08-04-2006, 11:10 AM
Nathan ross Nathan ross is offline
95 Caprice LT1 temp guage
The Temp guage on my 95 LT1 pegged on hot from the time you turn the key, is there a sensor some were that needs replaced?
Old 08-04-2006, 11:15 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: 95 Caprice LT1 temp guage
Yep souds like the sending unit iwre is burned through and grounded. Check on the left side between cylinder 1 and 3. Normally a green wire on older motors, not too sure on LT1's
Old 08-06-2006, 04:09 PM
Blue Bowtie's Avatar
Registered Offender
IIRC, the gauge temperature sender on a '95 is incorporated into the same body as the CTS. If the wire isn't grounded, but the sender terminal is, it's time to replace the sensor.
Old 08-07-2006, 10:37 AM
wrightz28's Avatar
You're probably right, that' s why I mentioned I wasn't too overly sure about on a LT1. But, same general concept is what I was trying for.
Old 08-07-2006, 11:01 AM
Registered Offender
You're right about the green wire, and all they did was merge the two devices into one unit, like the oil pressure sender/switches. I'm never too sure, either. That's why I mentioned "if I recall correctly"...
Old 08-07-2006, 11:34 AM
wrightz28's Avatar
Got ya
Old 07-01-2007, 01:32 PM
Don-D Don-D is offline
What Is The CTS Blue Bowtie.
Old 07-01-2007, 10:52 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Old thread, nearly a year old, please read the forum rules regarding age of threads.
The CTS stands for Coolant Temperature Sensor - the sending unit and sensor are one unit on the LT1 cars. Located on the driver side cylinder head between cylinders 1 and 3.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 07-02-2007, 10:22 AM
well since i posted that i now know that the "CTS" on LT1s is located between the 6 and 8 spark plug. But Thanks.
