Go Back   Automotive Forums Car Chat > Chrysler > Concorde
Old 08-04-2006, 09:57 AM
Trauma_Junkie Trauma_Junkie is offline
Where is the computer located? 94 concorde 3.5ltr?
I need to find the computer to check the connections. Where is it physically located? What does it look like?
I'm getting a 12 and a 27 code
Old 08-05-2006, 07:00 AM
CobraCDN's Avatar
CobraCDN CobraCDN is offline
Send a message via Yahoo to CobraCDN
Re: Where is the computer located? 94 concorde 3.5ltr?
The PCM (Powertrain Control Module) is located under the Air Cleaner Box (Passenger Front Corner under the hood). You need to remove the hoses & filter to the box and unbolt it to lift it out. The PCM sits beneath it like the following Illistration:
Remove the stud bolt and the push pin attaching the PCM to the body. The push pin has a center lock. Pull the center lock up to remove the push pin.
The 60way connector has a bolt on it which you loosen off to pull the connector.. clean it and re-insert it.. tighten only to 35 inch lbs. On the same side of the car up on the firewall you will notice a group f onnection there.. clean all of them also.
Code 12 is normal... code 27 in an open in an injector circuit.. usually a bad connection in wiring is the cause.
Cheers
