Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 08-04-2006, 02:16 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
piston selection help
My dad gave me a bit of a reality shock. This shit is going to cost some money, money that I dont really have. I found a rebuilt motor in the cities for $800 which is too much, but I would have payed it so I didnt have to go through the redtape of rebuilding. He had no recipts, no names of rebuilders, and no compression test so I said no. Well, now I have to rebuild my current engine. I was going to get the cheapest 8.5:1 pistons I could. Well, I can get OEM replacements for half of that. I am shooting for like 425. I know what compression ratio does for the performance, my question is how much of a difference does it make? I am thinking I am going to be able to get it out after probably 2 more days of working on it. My parents have no faith in my mechanical abilities despite getting the car running on the first try before it his the streets. I think I am going to rip it apart and see whats going on. I need to read a few good articles on rebuilding and I am going to tackle it "in the closet." It shouldnt cost too much money, especially if I do the assembly. Yes, I know I need to check clearances and that I need to read a lot more. Anyone thats built their own engines want to toss in the two cents?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 08-04-2006, 02:32 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: piston selection help
Rebuilding a motor will add up quicker than you expect it to once you start getting into all the little shit like gaskets and such... If you are limited on cash then maybe you should just do the 1g rod 2g piston combo and that'll raise your compression some and still be relatively cheap. But then again it could end up costing just as much as aftermarket pistons would because of the machine work needed done on the 1g rods to make the 2g pistons work... Not real sure what you should do there. As far as the rebuild, I honestly think that any of us that know every component to the engine and what it does can rebuild a motor... BUT, most of us lack the experience needed to do it. I guess theres a certain finess (sp?) to putting a motor together properly. I'm sure theres all sorts of little secrets and things to do differently on each kind of motor. The worst that could happen is that something goes wrong on your motor and it has to be rebuilt again. At least you would learn from it then if that happens... I would love to rebuild my motor myself too, but I just have too much money into all these parts to trust myself in doing it 100% right the first time.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 08-04-2006, 11:37 AM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
You had rod knock right? Why dont you just replace the bearings and it will cost you all of $100 probably less
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 08-04-2006, 11:05 PM
Thor06's Avatar
Jizzed In My Pants
Dont think a rod/the crank are junk?
Old 08-04-2006, 11:12 PM
blk_srt's Avatar
Measure it and find out. Cranks can always be turned to.
Mods:
Old 08-08-2006, 08:23 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Thor, pull the pan and check the rods and crank. If they aren't scored (scratched and gouged), measure them like Scott said, and you most likely will be able to put in some new bearings and be on your way. Otherwise if the crank is gouged, it'll need to be turned like Scott said and if the rods are fucked, you'll need a different set of rods at the minimum (rods can't be ground, or our rods anyways). Just my $.02.
95 Talon TSI AWD
97 Eclipse GST
