Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 08-04-2006, 12:43 AM
wildcat88stp wildcat88stp is offline
i have a 2.0 sohc and i want to swap with a srt4 neon engine
i have a 96 dodge neon with a automatic tranny and i want to swap a srt4 neon engian and tranny will all the motor mounts line up will it for what all will i need to do?
Old 08-04-2006, 11:28 AM
neon_rt's Avatar
neon_rt neon_rt is offline
Re: i have a 2.0 sohc and i want to swap with a srt4 neon engine
Do an internet search, there are several step by step how to's on the Web.
It is relatively easy for an experienced mechanic. As long as you have all of the tools you need, you should be able to pull it off (including welder and cutting torch). You will need a complete SRT-4 donor car plus you will need to purchase (or make your own) a mounting kit (the transaxle has to mount lower) and at least a STAGE 1 Mopar Performace upgrade kit.
You can also use a PT Cruizer turbo setup (GT Cruizer with manual trans), again you would need the complete vehicle. You need the MP upgrade kit b/c the SRT and PT cruizer engine control computer will only work on the vehicle it came from. There is a VIN # security scheme and century kit encryption that will prevent the engine from being started. From what I've heard you will need $4000-$6000 in your pocket to do this project.
