Go Back   Automotive Forums Car Chat > Buick > Century
Old 08-04-2006, 12:10 AM
gmmmy gmmmy is offline
subframe creak
1997 Century developed a strange creaking and thud noticeable at your feet on the passenger side, and slightly on the drivers side. This occurs ONLY when transitioning from throttle to brake or from brake to throttle.
Replaced motor mounts top and bottom, new Monroe struts (left the strut top mounting and bearing), checked tightness of suspension components. Upgraded the rear link bushings.
What next? I was told it could be control arm bushings.
New to the forum, help with this one could not be found using search.
Old 08-04-2006, 12:16 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: subframe creak
Welcome to AF.
I agree that creaking sound is typically the control arm bushings. What is your current mileage?
Timeslip 08/12/06
AF Community Guidelines
Old 08-04-2006, 12:23 AM
Re: subframe creak
108K. Un abused and in great shape.
Old 08-04-2006, 10:18 AM
BNaylor's Avatar
Re: subframe creak
I'd check out the bushings first with a visual inspection. But it sounds consistent with control arm bushings. The creaking is normally only there during some form of movement.
Timeslip 08/12/06
Old 01-30-2011, 07:27 AM
ekim17mr ekim17mr is offline
Re: subframe creak
Could it be rear subframe bushings as am having the same problem with my 98 century.When you turn the wheels the subframe moves and makes a creaking sound under the passanger feet
Old 01-30-2011, 12:19 PM
snshddog snshddog is offline
Re: subframe creak
I would agree on sub frame bushings, common around here. If I remember right for that year it is a 3 piece bushing but it could be a 1 piece.
