Old 08-03-2006, 09:42 PM
jtvyper456's Avatar
jtvyper456 jtvyper456 is offline
Send a message via AIM to jtvyper456
A/C Compressor
My Camaro is a 1995 with a 3.4, I'm looking into buying a used compressor and putting it in myself, but I've never done anything like this before...is it a simple takeout/put back in and recharge thing, or is it much more complicated than that?
1995 Camaro
40 Series Flowmaster
2 Kicker Comp 05CVR 122 (Dual 2Ohm Voice Coils)
^Kicker ZX550.2 Amplifier^
Old 08-03-2006, 10:18 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: A/C Compressor
Well the thing is its kinda against the law to let freon enter the air by opening the line which would be necessary to do for the home mechanic although shops depressure the system into a tank but if that was done, Its a simple disconnecting of hoses , taking off drive belt and removing threw bolts and then put it back together. Pretty simple really.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
Re: A/C Compressor
it can be more complicated. Your just taking the chance that the compressor is the only problem and that it didnt cause any other problems.
If you breaking the system seal then you need to evacuate the a/c system. They make special compressor tools to do the job. But ive heard of people using cheapo things that you can get at places like harbor frieght for about 10 bucks that create a vacuum when you hook them up to a compressor. Those should do the trick. After you evacuate then you can charge the system. If its a used compressor you should have a problem but I know with new ones you have to put in some compressor oil into the compressor before installing. You could replace the receiver dryer and the oriface tube while your at it since they are cheap things to replace and can cause all sorts of problems.
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 08-03-2006, 10:20 PM
Re: A/C Compressor
do you have to discharge r-134 into a tank too? or just the old stuff? he should have 134 in his car i would think.
yeah compressor intall is a piece of cake
Old 08-03-2006, 10:22 PM
jtvyper456's Avatar
Re: A/C Compressor
The clutches in the compressor are pretty much gone, it took 2 cans of R134A about 20 minutes to fully leak out...so it's not a simple swap out if I get a40 used compressor?
1995 Camaro
FormulaLT1's Avatar
Fight the powwa!!!
Re: A/C Compressor
95 was a transition year. He could have either/or, btw Harbor freight rules
Old 08-03-2006, 10:58 PM
Re: A/C Compressor
doesnt it! Got my engine stand there for 45 bucks. Solid stand too. 80 most other places.
Old 08-03-2006, 11:05 PM
FormulaLT1's Avatar
Fight the powwa!!!
Re: A/C Compressor
I have the entire automotive isle in my garage and a few of the hydrolic tools such as the shop press. Man the stuff is good and affordable and the service plans for a few dollars rock. I would so marry that store if it only had boobies . I go skipping threw there with my basket like little red riding hood .
Old 08-03-2006, 11:28 PM
Re: A/C Compressor
im not so sure that that is a good thing to admit....lol...
Old 08-03-2006, 11:33 PM
jtvyper456's Avatar
Re: A/C Compressor
Still not helping here ...so if I get the used compressor, change them out, and recharge with R134A, it should be good to go?
1995 Camaro
Old 08-03-2006, 11:47 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Re: A/C Compressor
No.
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 08-03-2006, 11:58 PM
Re: A/C Compressor
it should work but chances are high that the compressor could fail or the system not even work very well for very long if you dont evacuate the system first.
btw are you sure that the leak is at the compressor?
Old 08-03-2006, 11:59 PM
Re: A/C Compressor
you also need to make sure that your system is 134 or freon
Old 08-04-2006, 12:03 AM
jtvyper456's Avatar
Re: A/C Compressor
It is a 134 system, positive of that, and the leak is coming out from around the clutch area. So I should vac. the system out, then change the compressor out.
1995 Camaro
Old 08-04-2006, 12:04 AM
Re: A/C Compressor
First, where is the leak. A bad clutch won't leak. A bad shaft seal will. Is the clutch soaked with oil? If your going to replace the compresor, replace the accumulator and orifice tube. When you open the system, the accumulator begins soaking up the moisture in the air, that's bad. Orifice tubes stop up, and they're only 2-3 dollars. If you don't vacuum out the system, the air will react with the refridgerant and oil to create corrosive acids...
