Go Back   Automotive Forums Car Chat > Cadillac > Seville
Old 08-03-2006, 08:37 PM
sadillac sadillac is offline
2000 Cadillac Seville
I am driving along and my voltage is 14.5V, without warning, the voltage drops to 12.8 or 13.5V for 2-3 seconds. If my foot is not on the gas the car shuts off. It is like the car bogs down but I have been driving without any radio, ac..no draw other than the engine. New battery, cleaned throttle body, fuel filter, fuel treatment, air filter, only 93 octane. Any ideas?
Old 08-03-2006, 09:52 PM
caddydaddy caddydaddy is offline
Re: 2000 Cadillac Seville
How many miles? It sounds like a voltage regulator problem, maybe the alternator or a bad connection somewhere.
Also all 2000-up Northstar engines were designed to run on 87 octane. Under extreme driving, 89 is best, but your engine will very rarely have the need for 93 octane. You are just wasting your money. I have a 2000 STS and I drive it very hard and it runs great on 89 octane. Just a thought!
2000 Cadillac STS
2005 Cadillac Escalade
2008 Triumph Sprint ST 1050 ABS
Old 08-04-2006, 11:06 AM
mcnu's Avatar
mcnu mcnu is offline
I dont know if you know this or not, but in 2000, cadillac made the northstars so they can run on regular 87 octane.
98 Cadillac Seville STS
96 Cadillac Deville
Old 08-04-2006, 07:35 PM
Yes, that's what I said! But for optimum performance if you drive the car hard, 89 is the best to use!
2000 Cadillac STS
Old 08-18-2006, 10:00 AM
TAG781 TAG781 is offline
What about the 99?? I still have to use super??
Old 08-18-2006, 04:55 PM
If you use less than premium in a 1999 or earlier Northstar, the PCM may cut back ignition timing if it detects knock. This would reduce power of course. I've heard of people using 89 and even 87 and doing fine. And I'm sure it is if you're just a cruiser. But if you drive your STS like it was meant to be driven (fast and hard), then low octane gas isn't going to be the best choice.
2000 Cadillac STS
Old 12-26-2006, 08:16 PM
SickDaytona SickDaytona is offline
Just thought that I would let you know that I use 89 octane on my 99' SLS and have no issues. All good here.
Old 12-27-2006, 09:19 PM
And that's probably fine for most driving. But if you run it hard, the engine will probably cut back some ignition timing, so you'd have a slight power loss.
2000 Cadillac STS
Old 12-28-2006, 11:26 AM
butch h butch h is offline
You may have a momentary electrical shorting situation.
