Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 08-03-2006, 05:02 PM
bigdaddygnar bigdaddygnar is offline
Send a message via AIM to bigdaddygnar
friend wants a 2002 SER
i've heard there are problems with 02-03 Spec V's computers or something. is that the case with 02-03 SER's as well?
Old 08-04-2006, 05:13 PM
fugiot's Avatar
fugiot fugiot is offline
Send a message via MSN to fugiot
Re: friend wants a 2002 SER
yes sir, it is. 03's are much less problematic than the 02's, but the 04+'s are such a leap ahead, it's like Toyota made them
SR20 powered SE-R: 60mph-6.2 sec., 1/4mi.-14.7 sec.
VG30 powered Maxima SE: 60mph-7.8, 1/4mi.-15.8 sec.
Don't make me ANGRY
Or I will kick you in teh NUTS
Your NUTS will feel teh steel toe
Teh steel toe that has been in teh snow
I will rip off yuor pants and kick yuo in teh nuts
My steel toe will stick to yuor nuts
And I will swing yuo around by yuor nuts as I do a Hurricane kick
Old 08-04-2006, 05:19 PM
slideways...'s Avatar
slideways... slideways... is offline
theoretically, will a 04 ecu run an 02 car?
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 08-04-2006, 09:51 PM
ok, thanks
Old 08-04-2006, 11:46 PM
fugiot's Avatar
I don't see why it wouldn't, but the ECU isn't the only problem with the 02's and 03's. Shift linkages, knock sensors, O2 sensors, MAFs.....aaaand so on. Worst I've heard of were the connecting rods just breaking for no reason. That would suck.
Don't make me ANGRY
Old 08-05-2006, 10:38 PM
nismo_pilot nismo_pilot is offline
Send a message via AIM to nismo_pilot
04 ecu will not run a 02 car, slight tweaks and redesigns make them just different enough not to work, hence why technosquare looks for the "letter" code in your ecu to determine which flash to give it, pre-cats are problematic throught year range which can be solved by going to an aftermarket header, connecting rods are like popsicle sticks and cannot handle over 230ft-lbs of torque without rolling the dice on breaking, for NA applications this is more than enough but turbo forget it, butterfly screws on the intake mani can get sucked into the intake plenum if not loctited, there is a writeup on b15sentra.net for it, other than that have fun, its a great little car
2005 Aztec Red Spec-V
Nismo header, ES MMI, AEM CAI, UR Pulley, TB Coolant bypass, TWM SS, Kumho Ecsta's, 2x JL Audio W0 subs
9.02@ 84.4mph in the 1/8th....... Driver > Car
