Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 08-03-2006, 04:32 PM
nickledimed's Avatar
nickledimed nickledimed is offline
Send a message via Yahoo to nickledimed
front bearings
I am being told that the only way you can get the bearings for this vehicle is to buy the whole hub assembly, Is this true? if not were can I get the bearings? Orielys will not sell just the bearings If it is true...did I just buy a lemon?
08 Equinox LT
Old 08-03-2006, 06:00 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: front bearings
Welcome to the modern world of auto repair.
Yes most front wheel drives you have to buy the hole thing.
But look on the bright side you get a new ABS wheel speed sensor with most of them.
MT
MT
Old 08-03-2006, 06:55 PM
Re: front bearings
Look at the bright side?....hehe 234.00 compaired to around 25.00 for just the bearings.....Im not one for fixing things that are not broken. but...ok
oh yea...anyone have the torque specs for this hub assembly? I called around down here and i couldnt find anyone that had a manual for this montana. Ill have to order it, but I need to get this done before then.
Thanks
ps. anyone know were i can find a service manual for this van? I have tried haynes and chilton websites and it seems they dont carry one....hmmmm
08 Equinox LT
Old 08-03-2006, 09:19 PM
MT-2500's Avatar
AF - Advisor
Re: front bearings
Thanks
About 10 minutes and 24.95 US plastic and you can have a one year online sub for it.
http://www.alldata.com/products/diy/index.html
Axel shaft nut = Aztek is 192 ft lbs and just front whell drive van is 119 ft lbs.
Hub and bearing bolts is 96 ft lbs
And lug nuts is 100 ft lbs.
MT
MT
