Old 08-03-2006, 02:29 PM
4lynski 4lynski is offline
1997 caravan chk engine light code
had a fleet mech check diagnostics and code p0441 B came up..said had something to do with evap control and purge bad or something...wondering what I should check to replace first..I had him clear the code and hasnt came back, its been a few days...thanks
Old 08-05-2006, 05:48 PM
dooski dooski is offline
Re: 1997 caravan chk engine light code
Hi-- We own an 1996 Dodge Grand Caravan with a 3.3 V-6 engine and all the acsessories. It has Automatic Transmission, ABS, etc. Our Van has 110,000 miles on it. We have changed the oil every 3,000 miles. We bought it used in 1997 with 16,000 miles on it. In the past year or so our ENGINE LIGHT has come on several times. The Car Dealer we bought it from is 2 hours away here in New Hampshire, so we try to get our service done locally even though our local Dodge Dealer is the biggest rip-off ever, and their Technicians are not very "SKILLED" in their jobs!! Any-Ways! , When-ever our Engine light comes on, it happens because of a "loose-gas-cap". I never would have believed it, but whenever the wife fills up the van, soon after--- the "CHECK-ENGINE" light comes on! Apparently the gas cap needs to be put back on really TIGHT, or you will get this error code up on the dash. I may be totally wrong on this-- but give it a try and I hope this helps you out!! Good Luck! dooski--
Old 08-05-2006, 09:12 PM
Bear Bear is offline
Evaporative Purge Flow Monitor Failure. Insufficient or excessive vapor flow detected during evaporative emission sytem operation Sounds as if your cannister purge valve is bad.
Old 08-22-2006, 10:11 PM
rfitz3 rfitz3 is offline
Where is the evap purge valve?
Old 08-23-2006, 06:14 AM
Should be in engine compartment on passenger side near wiper fluid reservoir and next to the transmission control module (that metal box bolted to the fender). The cannister valve is black plastic and with engine running it MAY clikck on and off (mine does and it souunds like the belt tensioner pulley is bad).
Old 08-23-2006, 07:34 PM
vipergg vipergg is offline
The one poster is correct you will throw a check engine if you do not tighten the gas cap tight enough . you can tell when it is tight enough , it will click once and then its tight enough .
