Old 08-03-2006, 02:00 PM
Drfloppy Drfloppy is offline
97 grand prix A/C compressor oil ?
Hello, I have a 97 grand prix gt that has a bad ac compressor. I purchased a new compressor for the car, but on the box it says must add oil. so what I need to know is what is the oil and how much does it need.. The guy that I am going to have charge it for me does refrigeration for dairy farms and what not. He does have a oil, but I wanted to make sure it is the same stuff, and I have no idea how much to put in it.. so I figured no better place to come than here, because you guys always help me out. thank you so much !!
Dale
Old 08-03-2006, 02:12 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 97 grand prix A/C compressor oil ?
It is called PAG Oil #12345923 (old part number). The system needs 8 oz after a full evacuation. I am quite sure you can use the stuff available at the auto parts stores as long as it is for R134a systems.
Timeslip 08/12/06
AF Community Guidelines
Old 08-03-2006, 02:44 PM
BNaylor's Avatar
More info on PAG oils.
Double End Capped (DEC) PAG and Mineral Oils
PAG - 46 (Low Viscosity) Polyalkylene glycol developed for use in automotive systems using a low viscosity PAG in the presence of R-134A. Not for use in General Motors compressors.
PAG - 100 (Medium Viscosity) Polyalkylene glycol developed for use as a universal pag for auto systems using R-134A. This pag is compatible with most other pags available on the market.
PAG - 125 (GM Approved) Specially formulated Polyakylene Glycol that is General Motors approved as an after market service lubricant for Harrison Thermal System compressors.
PAG-150 (High Viscosity) Polyalkylene glycol developed for use in automotive compressors requiring a high viscosity polyalkylene glycol lubricant when HFC-134A is used. Specifically developed for use in General Motors compressors.
Timeslip 08/12/06
