Old 08-03-2006, 11:18 AM
h2ofowlman h2ofowlman is offline
Need Technical Assistance
I just bought a 2000 Metro 1.3L fuel injected motor very reasonable.
I have a '96 Metro that of course has a carburated motor and I would like to know what I need to put this fuel injected motor in my '96.
Thanks
Old 08-03-2006, 05:14 PM
mik13usa's Avatar
mik13usa mik13usa is offline
Re: Need Technical Assistance
GeoZuki and Crvette ... try to be nice!
Between these two characters, they have replaced or swapped or ... just about everything you can do with Geo engines. They will reply on this, I am sure. Just wait. By the way, the 1996 geo is injected, it is called TBI or Throttle Body Injection, I guess it could be mistaken for a carbureted version.
Good Luck!
Old 08-03-2006, 09:21 PM
geozukigti geozukigti is offline
Lol, ok, i'll behave myself . And yes, it is fuel injected. It sprays fuel right on the butterfly valve via a single fuel injector. The 2000 just has an Multi Point Fuel Injection setup and a bottle style air intake plenum. The 2000 is much better for performance, but they both get about the same mileage.
Old 08-03-2006, 11:36 PM
stamar stamar is offline
Thanks
um my 94 is fuel injected. 89 up fuel injection.
i have two cars with tbi both with 2 injectors. the suzuki version uses two injectors going to one bank assumedly one is low throttle one is high. like double barrel carburator.
my 89 dodge van has 2 injectors one for each side of the v8.
Ok check this out. I have long contemplated this. having 3 mpfi on 3 cylinders should actually be less effecient than 2 injectors through one throttle body. I mean think about it, one more injector but they all run at one jet size. I look at the chiltons manual i have and they show the same hp....
97 sentra gxe auto 174k miles
89 nissan d21 truck z24i 213k miles ( with a cabover camper)
Old 08-03-2006, 11:44 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
I'd rather have MPFI. The fuel doesn't pool up/fall out like it may do with throttlebody. I bet the flow rate on those 2 TBI injectors is higher than those 3 MPFI's. MPFI is more efficient..
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 08-04-2006, 12:17 AM
thats whats interesting. I dont think it is. Im going to have to look it up better a different day.
Old 08-04-2006, 02:41 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
think we got off the topic, your motor has a throttle body injector. the 2000 may have mpfi but the interchange book shows the head is different than the 96 so you can't put your intake on it and run it. you would probably have to swap the wiring out of the 2000 car to get it to work in your. sounds like a lot of work to me.
